savinien Posted February 21, 2006 Share Posted February 21, 2006 I got a 2001 Legacy L that I want to change the air intake and the Turbo on it. Where would I go to find the parts to accomplish such a task? Help Please. Also is it possible to split the exhaust off the 2.5L engine? Link to comment Share on other sites More sharing options...
MarcusDubya77 Posted February 21, 2006 Share Posted February 21, 2006 I didn't know 01's had turbos......... :woowoo:check out the Diamond Gray Metallic Monster!!! Link to comment Share on other sites More sharing options...
Aczwild Posted February 21, 2006 Share Posted February 21, 2006 Yea the 2001 GTs never had a turbo on them, do you want to add one? JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
LetItSnow Posted February 21, 2006 Share Posted February 21, 2006 OK, here's a start: upgrade your headlights to the top/bottom split, install the rear LSD, and upgrade the front springs to GT stock. Here's a better idea: Don't upgrade an L to a GT; it's not like making a replica 22b. How much are you looking to spend? We can guide you from there. Link to comment Share on other sites More sharing options...
savinien Posted February 21, 2006 Author Share Posted February 21, 2006 Well I don't really want to make a replica as to more of my own suped up Legacy. I love my car. I like the idea of upgrading the suspension. But first I want to upgrade the horse power. As for the turbo, I need to do some more research. I thought it already had the turbo in it to the high pitch sound it makes when you get high in your RPMs as if the turbo was kicking in. What about the air intake on the engine! What can I do to change that, like putting the scoop on the hood??? Link to comment Share on other sites More sharing options...
Aczwild Posted February 21, 2006 Share Posted February 21, 2006 The scoop isnt actually functional (its only on there for aesthetics in the US, but in japan they got a 2.0L twin turbo with a TMIC that utilized the scoop). I recommend doing the suspension, handling and brakes first, so you can stop and handle the power when and if you do turbo charge it. JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
savinien Posted February 22, 2006 Author Share Posted February 22, 2006 Ok Thank you. How much more power will a turbo give me that I would need to change my suspension? It's got what 165 HP now!?! Link to comment Share on other sites More sharing options...
andrew.anderson Posted February 22, 2006 Share Posted February 22, 2006 Ok Thank you. How much more power will a turbo give me that I would need to change my suspension? It's got what 165 HP now!?! Info on 2001 Legacy Line here Link to comment Share on other sites More sharing options...
Flanders Posted February 23, 2006 Share Posted February 23, 2006 OK, you are way off on a few things. Performance wise the only difference between and L and GT is suspension and brakes. There aint no turbo unless the previous owner put it in. A turbo kit will run you $4000 for parts only. Looking into an engine swap is the best option for turbo. You can get an intake and exhaust. www.boxer4racing.com is a good place. Link to comment Share on other sites More sharing options...
Aczwild Posted February 24, 2006 Share Posted February 24, 2006 OK, you are way off on a few things. Performance wise the only difference between and L and GT is suspension and brakes. Only in the BE/BH models, like yours There aint no turbo unless the previous owner put it in. A turbo kit will run you $4000 for parts only. Looking into an engine swap is the best option for turbo. If you do really want to go with a turbo you can only run about 5 psi of boost because like most NA motors, it is in no way really built to handle the turbo JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
SLegacy99 Posted February 24, 2006 Share Posted February 24, 2006 I opened my hood scoop up. Helped a lil bit. Link to comment Share on other sites More sharing options...
Flanders Posted February 24, 2006 Share Posted February 24, 2006 As for the turbo, I need to do some more research. I thought it already had the turbo in it to the high pitch sound it makes when you get high in your RPMs as if the turbo was kicking in. quote] I got the noise but not the kick! Link to comment Share on other sites More sharing options...
cbroo Posted February 26, 2006 Share Posted February 26, 2006 Turbo will cost you some money. In all Honesty you might as well drop a new engine in the car(WRX engine). For HorsePower go exhaust,( SPT, BORLA,) are good. Intakes, (INJEN), and suspension was my first upgrade I went with a rear whiteline swaybar, and a cusco front swaybay bar, and a front strut tower brace. then you'll get into a lot more money to upgrade stuff so far I've dropped about $1100 but most the parts were done my self so saved me some shop time. Link to comment Share on other sites More sharing options...
LetItSnow Posted February 26, 2006 Share Posted February 26, 2006 How much are you looking to spend? We can guide you from there. You can answer this question for us, if you want any real answers. Seriously. Link to comment Share on other sites More sharing options...
cbroo Posted February 26, 2006 Share Posted February 26, 2006 I opened my hood scoop up. Helped a lil bit. Is your car with a aftermarket turbo? cause I cant see much in helping unless you have some sort of short ram intake requiring more air Link to comment Share on other sites More sharing options...
