Vimy101 Posted November 13, 2006 Share Posted November 13, 2006 The chart still gives the pilots a 'good' rating in the snow. The Pilots are good tires. However since I was looking for an all season with good snow ability as my winter urban driving set up, I put more emphasis on the snow rating. I was seriously considering the WRs but the Conti price and local Discount Tire shop nearby sealed the deal. The Avons were also a possiblility but there were many complaints about noise once the tires had a season on them. Link to comment Share on other sites More sharing options...
mbcracken Posted November 13, 2006 Share Posted November 13, 2006 I have not noticed any flatspotting...but I have barely driven them. WHat pressures are you running? I'm running 35 psi all the way around. How about you? Link to comment Share on other sites More sharing options...
LawGT Posted November 13, 2006 Author Share Posted November 13, 2006 ^^ 36 front and 34 rear, cold (inflated with outside temps in the high 50's). I was running 37/35 cold when filled with outside temps in the mid 30's. Thus, when the tires warmed up in the hwy drive, hot temps were 41/39 (after 25 mile hwy drive), which made the tires to stiff for my taste... Link to comment Share on other sites More sharing options...
edmundu Posted November 15, 2006 Share Posted November 15, 2006 I agree with the other's about the snow capabilities of the Pzero's! I have now put about 600 miles on my recently installed Conti-Extremes, and let me just say this.....I have no regrets switching over to these:icon_bigg ! Some key differences: Conti-Extremes: Corner 98% as hard as the Pzero's, actually better in the wet, and ride a tad softer. Their turn in response is not as sharp as the Pzero's. They also are a notch noisier than the silent Pzero's.(when new.) Pzero's: Very crisp turn in response, have a stiff sidewall. Marginally better than Re92's in cold winter weather. BUT, they were no better in snow, and just as horrible in frozen slushy/icy mix. Near 4-5/32 tread remaining, they started developing a humming sound, which I first mistakenly attributed to a bad bearing. It also had great treadwear...I put 43k on them! Still had a little more left, perhaps another 2-3k. Bottom Line: Although I haven't driven the Conti's in snow yet, from looking at the tread design, they should prove to be superior to the Pzero's. If you are looking for a 4 season A/S tire the Conti's are clearly better. However, if you need a 3 season A/S, then it becomes much more favorable for the Pzero's. Only if you have rougher road surfaces, would I choose the Conti's over the Pzero's in this scenario. Hopefully this helps someone who's on the fence... Link to comment Share on other sites More sharing options...
