Eblues70 Posted June 11, 2008 Share Posted June 11, 2008 Thoughts on attaching to the hood and not the cover, IE what if you don't run the cover due to a Perrin TMIC and not drilling holes to reaattach? Link to comment Share on other sites More sharing options...
ih8vtec13 Posted June 15, 2008 Share Posted June 15, 2008 Wow this is a great idea, I was just wondering if it helps to protect the intercooler from soap. I don't want to throw off the ILL (Intercooler Lather Lock) sensor. Link to comment Share on other sites More sharing options...
SSN666 Posted June 15, 2008 Share Posted June 15, 2008 Too late. I fear that your brain lock was affected long ago. Link to comment Share on other sites More sharing options...
jaxx4k Posted October 29, 2010 Share Posted October 29, 2010 $10 buxx project awesome.. going to depo tomorrow... fall season I got so much leaves all over the IC. Link to comment Share on other sites More sharing options...
Subadozer Posted November 28, 2010 Share Posted November 28, 2010 Go to www.mcmaster.com - under "Raw Materials and Springs" pick "Metals" - click "Wire Cloth, Mesh, and Perforated Sheets" - look at the section titled: "Percentage of Open Area Range" You can buy a product that's similar to what's in the forward area of the engine cover and the gutter guard. It's called expanded metal lath and is used for plastering. Not sure about Lowes or Home Depot (probably varies regionally) but if they do plaster walls and ceilings in your area you should be able to find it at building supply places that sell plastering supplies. It's a galvanized steel rather than aluminum but should be a lot less expensive than some of the other options mentioned. A sheet of this will do quite a few intercooler covers as it comes in something like a 2'x6' piece. Link to comment Share on other sites More sharing options...
Brianjone5 Posted August 5, 2011 Share Posted August 5, 2011 I have just picked up an 05 outback XT wagon. There were quite a few bent fins on the intercooler ... This is a great idea. For the adhesive, you could use high temp gasket goop. If making this from two pieces of gutter cover material, you could use security wire instead of plastic wire ties. Harbor Freight carries it. (Wire used to secure nuts from vibrating loose). Link to comment Share on other sites More sharing options...
08GTLegacy Posted September 12, 2015 Share Posted September 12, 2015 What if you just covered it with a piece of plexiglass? That'd protect it.... /me looks around. What? Plexi would restrict airflow right? Sent from my XT907 using Tapatalk Link to comment Share on other sites More sharing options...
LatentWagen Posted December 31, 2015 Share Posted December 31, 2015 I'm gonna do this for the WRX, I think. 2005: I went to Lowes and could not find the 45 degree one. 2015: Plexi would restrict airflow right? ^ Concrete proof that the noobs of today are just as clueless as noobs of yesteryear... LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
