RangerMan Posted January 27, 2006 Share Posted January 27, 2006 When entering a turn, probably too fast, and the car starts to feel "floaty" and "loose" and slowing down tightens it back up and doesn't make it feel like you are sliding sideways - is getting too loose a function of suspension, tires or as I would suspect, both? And what are the ways to solve that? Not loose to the point that it feels like the car is going to rotate immediately, more like it feels as though the car's weight is being unloaded and a sideways translation is either occuring or about to occur. If the car continued to be pushed fast rotation would probably occur. Curious, and I don't know much about suspension or tires. Link to comment Share on other sites More sharing options...
D-2.5-GT Posted January 27, 2006 Share Posted January 27, 2006 sway bars, springs, and tires....most of your problems solved. Link to comment Share on other sites More sharing options...
RangerMan Posted January 27, 2006 Author Share Posted January 27, 2006 Thanks for the quick reply! Can you elaborate? I know that the tires will provide better traction, and assume that the springs and swaybar allow for a better contact patch? Link to comment Share on other sites More sharing options...
Jim L Posted January 27, 2006 Share Posted January 27, 2006 with the re92s my car wanted to be sideways all the time. Put on Hankook ice bears and tein h springs recently. They helped but have cusco sway bars coming in. After that I hope to get rid of the "floating" feel all together. Link to comment Share on other sites More sharing options...
sutter2k Posted January 27, 2006 Share Posted January 27, 2006 "Predictable" tires help. You can slide sideways and under control with tires that don't grib as well. Perhaps tires with a stiffer side wall. Some increased roll resistance will add some degree of confidence(springs, sway bars). e.g. the car will lean less. In addition, better shocks damper against sudden forces that "upset" the car. Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted January 27, 2006 Share Posted January 27, 2006 Tires first, then spring and sway bars...most of your problems solved. Fixed. OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
legacysteve68 Posted January 27, 2006 Share Posted January 27, 2006 yuppers Link to comment Share on other sites More sharing options...
iyalla Posted January 27, 2006 Share Posted January 27, 2006 The slide you are feeling is sometimes the tires rolling. The Re's are notorious for this. Link to comment Share on other sites More sharing options...
Hanger Posted January 27, 2006 Share Posted January 27, 2006 I made a fast right turn at high speed while raining, i was going to turn to the inner lane, but instead the car slided to the outer lane, f scary ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
magnetic1 Posted January 27, 2006 Share Posted January 27, 2006 To answer your question (thread title), its actually a function of speed But assuming you dont want to slow down... you need better tires first. Remember though... slow in, fast out. The whole process you mention about turning, understeering, skidding until the car slows down enough then "re-grips" is all based on the friction circle. Up to the point of understeer, you can turn. Once you start sliding/understeering, anymore steering input you give will do nothing. You need to optimize your entry speed to apex... and then power out. This is also based on weight distribution and many other things. Swaybars will help keep the opposing tire planted... so: 1) entry speed correction 2) tires 3) shocks/springs 4) swaybars Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
dvdt Posted January 28, 2006 Share Posted January 28, 2006 Assuming you are still stock...The quick cheap thing to do is add air to your tires. Say 38/36 or so. That will help a little. Not enough, get betters tires, then springs/coilovers, sways last. Tires will make the biggest difference. Link to comment Share on other sites More sharing options...
Opie Posted January 28, 2006 Share Posted January 28, 2006 Loose is faster.... Link to comment Share on other sites More sharing options...
caramall2 Posted February 4, 2006 Share Posted February 4, 2006 While were on the subject...are swaybars a must? I'm getting coilovers (GP 7k springs, just have never had and want to play around with them) and new tires, and wondered if stiffer swaybars are really a must for improved handling? If so, I'll slap em on, but seems to be some differences of opinion. thanks all. AC Link to comment Share on other sites More sharing options...
magnetic1 Posted February 4, 2006 Share Posted February 4, 2006 While were on the subject...are swaybars a must? I'm getting coilovers (GP 7k springs, just have never had and want to play around with them) and new tires, and wondered if stiffer swaybars are really a must for improved handling? If so, I'll slap em on, but seems to be some differences of opinion. thanks all. AC I dont think there is a coilover kit for the LGT that allows easy and interchangeable springs to change the rates. Ideally, you'd change the spring rates to tune for handling for each end of the car... then you'd adjust the swaybars for fine tuning. Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
Xenonk Posted February 4, 2006 Share Posted February 4, 2006 a loose car is a characteristic of the car's design (assuming you are driving to the limits or higher). The entire can get light on you, so depending on how you balance your grip on all 4 tires will still be a combination of all three areas of interest: 1) understanding what your car can do 2) understanding that your suspension can only give you so much resistance of roll and squat 3) understanding how much grip your tires have based on speed, slip angle, and road conditions Typically, you can be on ANY tire and eventually lose grip as Magnetic1 stated will be a speed issue and the friction circle, your tires can only do so much at a given time. Read up on slip angles if you can, it will give you some idea of what certain tires can do while driving at higher speeds. Keefe Link to comment Share on other sites More sharing options...
