afomenko Posted January 26, 2006 Share Posted January 26, 2006 I replaced belts on my wife's 2000 Outback in November 2005 with Dayco Poly Cog belts (made in Canada). Audvance Auto Parts rep was selling on "much better reliability" and other... I would not say car really needed it - but I was doing maintenance on leaked radiator, so decided to replace belts just to forget about maintenance for some time. So... 2 months later and 4000 miles later it failed miserably after multiple adjustments. It was stretching to the slip point and I was tensioning it probably 6-7 times, until I hit limiter. 2-3 weeks later it was overstretching/slipped and cycle repeated itself. Belt had "1-yr replacement warranty", but apparently only from the "breakeage". Now it is replaced with Gaites, which was MUCH HARDER to put on, and it works for the second week already with no sign of stretching or slip. Dayco Poly Cog was TOO soft from the very beginning, but I desided to give it a try anyway... So... beware... Link to comment Share on other sites More sharing options...
Bicster Posted January 27, 2006 Share Posted January 27, 2006 Interesting. But why not use OEM belts? Link to comment Share on other sites More sharing options...
dark_rex Posted January 27, 2006 Share Posted January 27, 2006 Dayco is an okay brand. Having been in the aftermarket parts business, I had good luck with Gates as well. OE = unneccesary $$ for most stuff. I never understood why people go to the dealer for basic replacement parts like pads, belts, fluids, etc. dR Link to comment Share on other sites More sharing options...
bluesuby Posted January 27, 2006 Share Posted January 27, 2006 I too had a bad experience with the Dayco cogged belts. My old Chevy threw the alternator belt on the way home a couple years ago. Fortunately the battery carried me the next 20 miles though the turn signals and headlamps were very dim at the end. Link to comment Share on other sites More sharing options...
mmanus88 Posted January 28, 2006 Share Posted January 28, 2006 sounds like a type of condom Link to comment Share on other sites More sharing options...
PhilT Posted January 28, 2006 Share Posted January 28, 2006 I replaced belts on my wife's 2000 Outback in November 2005 with Dayco Poly Cog belts (made in Canada). Audvance Auto Parts rep was selling on "much better reliability" and other... I would not say car really needed it - but I was doing maintenance on leaked radiator, so decided to replace belts just to forget about maintenance for some time. So... 2 months later and 4000 miles later it failed miserably after multiple adjustments. It was stretching to the slip point and I was tensioning it probably 6-7 times, until I hit limiter. 2-3 weeks later it was overstretching/slipped and cycle repeated itself. Belt had "1-yr replacement warranty", but apparently only from the "breakeage". Now it is replaced with Gaites, which was MUCH HARDER to put on, and it works for the second week already with no sign of stretching or slip. Dayco Poly Cog was TOO soft from the very beginning, but I desided to give it a try anyway... So... beware... There's your problem Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
afomenko Posted January 28, 2006 Author Share Posted January 28, 2006 Well, it seams to be my first aftermarket non-USA-made belt... And I had at least 8 replacements so far... Gaites and non-cogged Dayco worked fine before. Link to comment Share on other sites More sharing options...
