Generic adapted NPT oil pressure switch compatibility?
While rebuilding our type ra block we decided to run an oil pressure gauge instead of relying on an idiot light so I bought the gauge which required us to swap out the oil gallery adapter to npt. I ended up getting a relocation kit due to space constraints and I added a splitter because it would be nice to still have the idiot light hooked up but now we have an issue where the splitter is npt and the OEM sensor is bsp which doest not provide a fit. I think running adapters back down to bsp would cause some space constraints.. Could I just buy a generic npt sized sensor and run that? I attached a picture to show what I got going on
Edited by nebula72
Typo
  • nebula72 changed the title to Generic adapted NPT oil pressure switch compatibility?
Engine Build - Click Here
Thinking more about it, you might be able to find a 45 degree street elbow. I used to make test set-ups in the Aero-Space industry, I've been using Parker fittings for decades.
You could always use the oil galley at the back of the block by the turbo.
I still don’t know if my oil pressure sending unit will clear the alternator either yet… but if not, I will do the remote setup like you have. I had to pull apart the wiring harness a little to free up the factory ‘replace engine’ sensor, but whatever. I didn’t want to have to put electrical tape on the cluster.
But you can use the factory bsp plug for the rear galley and the npt one up front. (Or vice versa)
IMG_3917.thumb.jpeg.b1cef29fceabba923e8a9c5c24e85a9a.jpegIMG_3918.thumb.jpeg.dd24519b9d054b705353d5e959040c94.jpeg
There was no Teflon tape because I was just mocking it up with the OEM oil pressure sensor. I found an npt style sensor at AutoZone and I think I'm going to try it this is what it looks like
