GearJamr Posted April 15 Share Posted April 15 I was cleaning the Valenti taillights I have after repairing a piece that had broken off during shipping. That side is good. The passenger side (which was untouched) apparently has a small leak somewhere in the seal. Should I take it apart and re-seal it, or would a small bead of silicone be good enough? Link to comment Share on other sites More sharing options...
silverton Posted April 15 Share Posted April 15 To do it the right way you would want to bake it apart and reseal it, but you could try a bead on the outside... I've sealed up some rear cam plug leaks this way 1 Link to comment Share on other sites More sharing options...
GearJamr Posted April 15 Author Share Posted April 15 I only found it because I was wet sanding the epoxy area where I did the repair. Figured I might as well give them both a sanding and polish. The leak seems to be at the bottom (when it is mounted on the car), and that is the only location water dripped out when I moved it around. Thought maybe a quick bead of silicone might be enough, but the re-seal does seem the better way. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 7 Share Posted May 7 Sorry to be late to the game. Years ago I just put a bead of silicone around the seam in the right tail light. I took it off on a warm sunny day. Let the l housing bake in the hot sun so it really dried out. Then just ran a bead around the seam. Let it cure and put it back on the wagon. That worked for me. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GearJamr Posted July 9 Author Share Posted July 9 I just resealed the offending taillight on the weekend. One of the few things I actually accomplished without massive failure while I was off last week. 2 Link to comment Share on other sites More sharing options...
