peril Posted February 23 Share Posted February 23 (edited) Hey All - so I did this serpentine belt in the past year or so - and it just snapped as my kiddo was driving up. car is about 160k miles, (all is well otw) - any diagnostics or replacements you recommend? order for me is 1) check spinny and bearing noise on tensioner pulley, (check alignment) (this was ok last time) 2) new belt - duh 3) check "feel" of alternator Is there anything else you recommend I check out? He let me know he felt the power steering get harder - so figure the belt snapped as he was driving. he got about 10 miles ish - then the battery died (or at least started acting wierd in the car when the voltage started to drop ) --Adrian Edited February 23 by peril Link to comment Share on other sites More sharing options...
peril Posted February 23 Author Share Posted February 23 ah -yes - well - idler pully bearing gave up the ghost - shredded the belt - pretty obvious. 1 Link to comment Share on other sites More sharing options...
creep_nu Posted February 23 Share Posted February 23 well that was a quick way to answer your own question haha. glad it's something pretty straight forward 1 Link to comment Share on other sites More sharing options...
peril Posted February 23 Author Share Posted February 23 now to the fun part - the air conditioner mounting bracket has a post that got chewed up - going to need to replace. Also on a bit of a rat hole to replace the bearing on the tensioner / idlers as maintence items. going to fix up the tensioner bearing while I have this on the mind. (The idler is toast - need a new one.) 6203 steel caged bearings from amazon here I come. Adrian 1 Link to comment Share on other sites More sharing options...
creep_nu Posted February 23 Share Posted February 23 best of luck! Link to comment Share on other sites More sharing options...
silverton Posted February 23 Share Posted February 23 I always recommend new idlers/tensioners when a car needs a belt. Most people dont buy them but it's the right way to do it. 2 Link to comment Share on other sites More sharing options...
peril Posted February 23 Author Share Posted February 23 for hte actual tension of the tensioner pulley - what is that torque? Is that the same as the idler pulley? I don't see that here Link to comment Share on other sites More sharing options...
peril Posted February 24 Author Share Posted February 24 (edited) All done ! The idler mangle on the bracket is manageable for now - if it dies again - I replace the bracket. idler pulley (mine was bent ..) (following worked well) -> https://www.amazon.com/gp/product/B009HL6VY2/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 Bearings for tensioner pulley -> https://www.amazon.com/gp/product/B08XZHN9NS/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 and just a standard belt. and this little diagram is the shiz. Edited February 26 by peril 2 Link to comment Share on other sites More sharing options...
peril Posted February 24 Author Share Posted February 24 23 hours ago, peril said: for hte actual tension of the tensioner pulley - what is that torque? Is that the same as the idler pulley? I don't see that here I did 30ish lbs with a box wrench - tight - but not crazy tight. Link to comment Share on other sites More sharing options...
SchwarzeEwigkt Posted March 4 Share Posted March 4 (edited) I realize that I'm late to the party on this one, but I had squeal coming from the accessory belt system and was scandalized by the cost of simple pulleys. I bought new Timken bearings for both the idler and tensioner pulleys and drove them in with a bolt, washers, nuts, and a combination of aluminum seal driver plates and cast steel plates from a FWD bearing press kit I have laying around. It did not, however, solve the issue for long. Turns out that while the bearings were a little chewy and definitely should have been replaced, the issue ended up being my alternator being on its way out. I've not had any weird noises since I replaced the later dead alternator. That said, those bearings absolutely can be replaced for a couple bucks and a bit of your time, assuming your pulleys are still in good shape and you're willing to fabricobble something together to drive them in. Edited March 4 by SchwarzeEwigkt Left something out. 1 1 Link to comment Share on other sites More sharing options...
peril Posted March 25 Author Share Posted March 25 Driving that sucker in there was a bit scary - I used a 32 or 36 impact turned around and it fit PERFECT into the same space as the bearing - scared the crap out of me that I wouldn't be able to get it out. Link to comment Share on other sites More sharing options...
