JayLadzinski Posted February 9 Share Posted February 9 I need to replace the driver side (left side) mirror on my 2023 legacy. Pretty sure I have the limited series. Mirror is heated, has turn signal, and blind spot alert light. They manually fold in either direction (although didn't fold when I backed into a pole). Looks like parts damaged are the Ice Silver Metalic (G1U) Upper cap, the black lower cap, turn signal casing, and the glass. Trying to order parts, but cannot see any actual photos to confirm parts are correct. Link to comment Share on other sites More sharing options...
DrD123 Posted February 9 Share Posted February 9 (edited) So Subaru doesn't sell the mirror scalps painted, so you'd need to do that on your own (lots of companies sell color matched paint in a spray can - www.paintscratch.com is one I have used before) - for the mirror cover, that's 91059AN02A, for the lower part, that's 91054AN12A, and the mirror glass is 91039AN02A. For an extra $20 or so, you can actually buy the whole assembly (91036AN82A) (still unpainted) https://parts.bestbuysubaru.com/a/Subaru_2023_Legacy-25L-Limited-Sedan/_51505_7628466/REAR-VIEW-MIRROR/B16-912-01.html poking around ebay, found the mirror glass for alot less https://www.ebay.com/itm/143402294733?hash=item2163715dcd:g:e10AAOSwH4tdl3f4&amdata=enc%3AAQAIAAAA0BXILcaDEcHGN%2FjMZjPi3lm2oa8B5iz%2Bimz0wgMwXBwBpSwL9u%2FffUXm8k4l5da47lTlveJdhlcSpfqHeUePSpQ5MqIbxvXeJGy4OrKsGyTXeEi8h%2FvZCyMvy28p59DC%2B%2FG0%2FK88YF%2BBWoI4vKEJyP8hWqBvduHmtSdo0yFEmWwEXZ1iSGhLfgDZd5Fb6bJT%2B7aH3vC3mQM29Cd12ipXML1EIrJgViacIJaU%2FMJjjLNcnblhQNzQV90I%2BWXkKqyi6KmI83x%2B4g%2BKqTjwXSOFm3s%3D|tkp%3ABk9SR-6P3PmxYw Edited February 9 by DrD123 1 Link to comment Share on other sites More sharing options...
Painless Posted February 21 Share Posted February 21 I have a spare L&R side mirror covers but they may not fit your year. Part number inside says "VB26 A6082-510 R" and "VB26 AB145-547 L". The Subaru P/N I assume to be "91059FL11A" and "91059FL12A". They are from my 2016 & 2019 Legacy's and already painted Crystal White Pearl. Link to comment Share on other sites More sharing options...
