olivierdb Posted January 22 Share Posted January 22 I'm having a issues in cold weather. When i start my car it charging at low voltage 11.4 ish. After maybe 2-3min idling the battery light goes out and the voltage goes up to 13.9 . Alternator and the battery or brand new. Eny advice? Does the pcm control the voltage or it all done on the alternator side? Link to comment Share on other sites More sharing options...
rhino6303 Posted January 23 Share Posted January 23 Alternator, cluster, and a fuse control the charging system. Check the alt-s fuse in the engine bay. 1 Link to comment Share on other sites More sharing options...
Haze Posted January 23 Share Posted January 23 My OBXT does the same thing. Happens when starting it after sitting outside below roughly 0°F. I've been through everything in the charging system I can think of and haven't found anything wrong. It hasn't become any worse over time and has never stranded me so I gave up trying to fix it. 1 Link to comment Share on other sites More sharing options...
olivierdb Posted January 25 Author Share Posted January 25 On 1/22/2024 at 8:01 PM, rhino6303 said: Alternator, cluster, and a fuse control the charging system. Check the alt-s fuse in the engine bay. I put a new alternator fuse in. And this morning my light was still on. Link to comment Share on other sites More sharing options...
rhino6303 Posted January 25 Share Posted January 25 8 hours ago, olivierdb said: I put a new alternator fuse in. And this morning my light was still on. Check the wires at the connector on the alternator. Remove it and inspect it. Link to comment Share on other sites More sharing options...
