Beamercub Posted December 25, 2023 Share Posted December 25, 2023 BaH-hum-Bug. 20231225_094848.mp4 Link to comment Share on other sites More sharing options...
Beamercub Posted December 25, 2023 Author Share Posted December 25, 2023 I just noticed on RockAuto that they sell just the Boot and spring ? Is that a thing? Curious if anyone else has just replaced the Boot and spring and kept the original coil? Link to comment Share on other sites More sharing options...
Beamercub Posted December 25, 2023 Author Share Posted December 25, 2023 Link to comment Share on other sites More sharing options...
silverton Posted December 26, 2023 Share Posted December 26, 2023 I don't have much professional experience with 3.6's but one did come through with a single cylinder misfire, replaced a bunch of stuff....ended up being the ECM. Before you buy anything swap coil positions just to see. when were the spark plugs replaced? good luck! Link to comment Share on other sites More sharing options...
Beamercub Posted December 26, 2023 Author Share Posted December 26, 2023 Ok. I got a new subaru coil today and went to replace it and I can't get the bolt off?! And the clip that attaches to the coil appears to have melted ! Called subaru and asked if I could order a new clip and repin it.. They replied with NO. That i would need a whole new harness? Does anyone know where I can order a replacement clip that I can repin? I'm really at a loss for getting the darn bolt out.. It just won't move.. Thought about letting it warm up and then trying to get it out? Any help/ suggestions please.. Attached a pic of the melted connector.. Link to comment Share on other sites More sharing options...
Infosecdad Posted December 26, 2023 Share Posted December 26, 2023 Dang, that coil looks toast. Single: https://iwireusa.com/products/ignition-coil-plug-c Four Pack: https://iwireusa.com/collections/3-pin-replacement-plugs/products/gray-coil-pack-plug-kit PB Blaster and/or heat should help loosen the bolt. 1 Link to comment Share on other sites More sharing options...
silverton Posted December 26, 2023 Share Posted December 26, 2023 I use a 12mm socket on a 1/4 ratchet... do be careful with those connectors, they break if you look at them wrong. 1 Link to comment Share on other sites More sharing options...
