Beamercub Posted December 22, 2023 Share Posted December 22, 2023 Timing chain... A topic i haven't heard much about? As with lifetime CVT fluid, what about the timing chain? Tensioner? Any insight is appreciated. Link to comment Share on other sites More sharing options...
ammcinnis Posted December 22, 2023 Share Posted December 22, 2023 Do you see "timing chain" mentioned anywhere in the Subaru Schedule of Inspection and Maintenance Services for your 2015 Legacy? Your answer is there. You can also consult the 2015 Legacy/Outback Factory Service Manual for additional information. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
Beamercub Posted December 22, 2023 Author Share Posted December 22, 2023 hmm. Either you are being direct or sarcastic. Thanks for the info. Link to comment Share on other sites More sharing options...
silverton Posted December 22, 2023 Share Posted December 22, 2023 chains are generally good for the life of the engine. if you regularly have hard tapping noise that subsides real quick from the engine on cold start you may need guides/tensioners, otherwise... that's the point of a chain, to not worry about it. 1 Link to comment Share on other sites More sharing options...
Beamercub Posted December 23, 2023 Author Share Posted December 23, 2023 2 hours ago, silverton said: chains are generally good for the life of the engine. if you regularly have hard tapping noise that subsides real quick from the engine on cold start you may need guides/tensioners, otherwise... that's the point of a chain, to not worry about it. Thank you for the insight. I really appreciate it. I guess thats why I haven't heard anything about the timing chains. Link to comment Share on other sites More sharing options...
