Crisfer Posted November 16, 2023 Share Posted November 16, 2023 Hello everyone new to the forums I'm doing a timing belt water and oil pump on this 09 spec b upon inspection I noticed this sticking out a bit looks like crank bearing what are your thoughts? Link to comment Share on other sites More sharing options...
Haze Posted November 18, 2023 Share Posted November 18, 2023 That's exactly what it is. Not sure what could cause that other than the bearing shell being improperly installed in the first place. There's a small tab on the back side of the bearing that fits into a corresponding notch in the block. That tab would have to be either crushed or sheared off for the shell to sit where it is. 1 Link to comment Share on other sites More sharing options...
subaru-tech Posted November 19, 2023 Share Posted November 19, 2023 That's the part of the crankshaft that the front crank seal in the oil pump seas against. 1 Link to comment Share on other sites More sharing options...
Crisfer Posted November 19, 2023 Author Share Posted November 19, 2023 Thanks for replying I advised my brother on this and let him know that it's a problem, since he has been driving it like this I'm hoping he can get a few more miles on it. Link to comment Share on other sites More sharing options...
Haze Posted November 19, 2023 Share Posted November 19, 2023 Just to clarify, the pen is pointing to where the oil seal sits. The problem is the thin piece protruding between the crank and block a bit further back. 1 Link to comment Share on other sites More sharing options...
Crisfer Posted November 19, 2023 Author Share Posted November 19, 2023 Yes where the oil seal sits but it would be inline with the oil pump rear cover pump sits flush once in place. Link to comment Share on other sites More sharing options...
Crisfer Posted November 19, 2023 Author Share Posted November 19, 2023 2 hours ago, subaru-tech said: That's the part of the crankshaft that the front crank seal in the oil pump seas against. Yes. Link to comment Share on other sites More sharing options...
