subaru-tech
Members-
Posts
43 -
Joined
Content Type
Profiles
Forums
Gallery
Everything posted by subaru-tech
So I'm going to be lowering my daughter's outback after winter. I'm wondering what a good offset for flush wheel fitment would be. I currently run a +48 on my lgt and my wheels sit pretty flush. I'm worried about being flush on the wider body and rubbing the wheels. Pics are also welcome for her to see what wheel style she may like. Thanks!!!! Pic of my car.for attention lol.
That's the part of the crankshaft that the front crank seal in the oil pump seas against.
ABS System Issues
subaru-tech replied to TainoPapiChulo's topic in Fourth Generation Legacy (2005 - 2009)
So for some reason on these generation legacys when you get abs codes, especially on automatics it causes them to run terrible and they kick the fans on too. Now on subarus there's 2 terminating resistors for the can network. One in the ecm and one in the vdc. You can use pins 6 and 14 of the dlc connector to.check the can network. You should get 60 ohms with everything plugged in, if you ger 120 ohms youve lost a terminating resistor. My guess by the symptoms your having is the vdc module took a dump and is messing with the can network. This is where I would start. -
Engine lift points
subaru-tech replied to relative4's topic in Fourth Generation Legacy (2005 - 2009)
I usually use a jack.and block of wood under the front diff. -
Sounds like the fan motor is shot. If you have to push the fan to get it going, the brushed are probally bad.
- 2 replies
- 1
- cooling
- radiator fan
(and 3 more)
Tagged with:
Official Atlantic Blue Thread Volume-2
subaru-tech replied to SBT's topic in Legacy Photos (2005-2009)
Thankyou -
I know, I order a lot of parts from him. Top quality -
Underdog Motorsports - 2015 STI Steering Rack Swap
subaru-tech replied to Underdog's topic in Suspension/Brakes
When I did my swap I used a 2015 sti power steering pump. The pressure is a little higher and aids in the judder when turning fast -
www.mysubieparts.com has one for sale right now. -
'05-'09 Paddle shifter setup
subaru-tech replied to Rittmeister's topic in Member Classifieds (2005 - 2009)
I'm intrested but have to wait 2 more weeks for taxes -
Clutch replacement 05 Legacy GT
subaru-tech replied to hateitorloveit's topic in Fourth Generation Legacy (2005 - 2009)
That kit is perfectly fine. You'll notice a difference with the lighter flywheel too. This is the kit I went with because of the mods I have and am planning to do. https://www.importimageracing.com/products/sb11-hdss-act-heavy-duty-street-sprung-clutch-kit-w-flywheel-subaru-wrx-2006-2021?currency=USD&variant=44929130131&utm_medium=cpc&utm_source=google&utm_campaign=Google Shopping&gclid=CjwKCAiAy_CcBhBeEiwAcoMRHIFpXuGHepdiruxFBQ5uRSVnPcM8J4wdVSvtGSQXF2aBZcc4YM2aMRoCTAcQAvD_BwE -
There is a reprogram all ascent and xt cars get that are under the recall. Then the car is checked for slippage, then the chain guide is checked. If there is any slippage recorded the vehicle automatically gets a new trans. The issue was in the old programming. The new reprogram takes care of any issues.
Weird window problem
subaru-tech replied to Kayaker's topic in Sixth Generation Legacy (2015 -2019 )
We see this problem all the time at the dealer, especially with smokers. The window run gets dirty. I soak a rag in brake clean and use a flat head screw driver to clean the channel. Sometimes I have to put so.e lube on the window run. -
Depending on hourly rate, book time is around 7 hours. If your going to do an exedy clutch, get one for a 06 wrx and get the 06 wrx flywheel. Get rid of the dual mass flywheel. You will need tonget new flywheel bolts as well. The dual mass flywheel is expensive. -
ER HC, what does it mean??
subaru-tech replied to Fuzzybaseball58's topic in Fourth Generation Legacy (2005 - 2009)
It means error on the high speed can network -
I used 08 and up sti strut mounts
fs - location: Legacy wagon bp5 rear bumper spats
subaru-tech replied to subaru-tech's topic in Member Classifieds (2005 - 2009)
Sold -
Replacing the pinch bolt
subaru-tech replied to Florian_pigl3t's topic in Third Generation Legacy (1999 - 2004)
If you drill the old one out and drill it straight, a grade 8 3/8 bolt and nut works perfectly fine
