VebLar Posted November 4, 2023 Share Posted November 4, 2023 Hi! My Legacy's suspension has started to sag a bit, especially when towing or filling the boot. I have been looking for stiffer springs, but they all seem to drop the car, which i really don't want, as i find it a bit low already, and could actually do with a 1' lift. What possibilities do i have? I have read about 12-13' suspension fitting and that being a bit stiffer. Would that be a decent upgrade, combined with a 1' lift from blocks? Or, is it possible to mount struts and springs from an Outback, and get the lift and stiffness from those? On a sidenote, I've heard lots about the problems of the ee20, especially the Euro4 version. My car is registered with a Euro5 emissions class. Is it possible that I've gotten the Euro5 engine, even though it's an early 2010? This is a Norwegian car, so there migt be early Euro5 versions up here? Link to comment Share on other sites More sharing options...
DrD123 Posted November 4, 2023 Share Posted November 4, 2023 With USDM cars, the 13-14 springs are definitely stiffer and a worthwhile upgrade. For struts there are some options to tighten things up - lots of us have gone with Koni's (the cut-a-strut for the fronts and shocks for the rears). Larger swaybars also help. (I have the 13 springs all around, Koni adjustables for struts, a 26mm front and 19mm rear swaybar and am pretty happy with the car as a daily driver. Outback components would probably work, but I think you need more than just struts and springs - looks like maybe the front swaybar, front/rear endlinks, and rear upper control arms? could be some other stuff, too. Link to comment Share on other sites More sharing options...
Alexmed2002 Posted November 5, 2023 Share Posted November 5, 2023 8 hours ago, DrD123 said: With USDM cars, the 13-14 springs are definitely stiffer and a worthwhile upgrade. For struts there are some options to tighten things up - lots of us have gone with Koni's (the cut-a-strut for the fronts and shocks for the rears). Larger swaybars also help. (I have the 13 springs all around, Koni adjustables for struts, a 26mm front and 19mm rear swaybar and am pretty happy with the car as a daily driver. Outback components would probably work, but I think you need more than just struts and springs - looks like maybe the front swaybar, front/rear endlinks, and rear upper control arms? could be some other stuff, too. +1 on the 13-14 springs. They really nailed them during those years. Link to comment Share on other sites More sharing options...
VebLar Posted November 5, 2023 Author Share Posted November 5, 2023 Looks like 13-14 springs are the way to go then. Will it be beneficial to just upgrade to new springs, without new shocks? Being a student, cost effectiveness is very important Link to comment Share on other sites More sharing options...
Plastixx Posted November 5, 2023 Share Posted November 5, 2023 (edited) If you still have the 13 year old OEM struts, I personally wouldn't go through the trouble of putting new springs on them. Get a new set of KYB at the least. They aren't that expensive. Edited November 5, 2023 by Plastixx Link to comment Share on other sites More sharing options...
NVAKeith Posted November 8, 2023 Share Posted November 8, 2023 Here’s a long build thread on lifting a legacy. Link to comment Share on other sites More sharing options...
