Coil spring compatibility 1993 AWD legacy sedan
Been a month or two into getting my unfortunately wrecked Subaru back on the road. Almost there but I can’t find a replacement coil spring supposed to fit my legacy. Will a coil spring from a newer model more or less get the job done?
  • 2 weeks later...
'93-'01 Impreza rear stuts/springs (full take offs) will work, too.  Unless your struts are new,  I'd go w/those. But double-check online that you won't get the 'saggy butt' - where the rear sits lower than front.
LegacyCentral BBs should have that info, too. https://bbs.legacycentral.org/viewforum.php?f=6
To answer your question: I believe there were some differences in the rear springs in the '90s with some being tapered and won't fit your stut's perch and/or top hat. And '95+ Legacys had different rear top hat bolt patterns, so they won't just bolt on. Probably covered on some other Subie sites, such as the USBMB.
Edited by wtdash
