InfinX Posted June 21, 2023 Share Posted June 21, 2023 the first photo is of the bumper I have now is it possible to put the bumper and grill in the second photo onto the car in the first photo. does everything match up together? Link to comment Share on other sites More sharing options...
m sprank Posted June 24, 2023 Share Posted June 24, 2023 Need more info. Cant tell you from a pic. Link to comment Share on other sites More sharing options...
silverton Posted June 25, 2023 Share Posted June 25, 2023 Pretty sure that's the same bumper, but with a lip....... Link to comment Share on other sites More sharing options...
m sprank Posted June 25, 2023 Share Posted June 25, 2023 I am thinking its a Albero or something like that. In which case we need to know if the car in the first pix is usdm, edm or jdm. Then we need to know which hood, lights and fenders it has. If it is a usdm car with a jdm front bumper swap the Albero should fit. Link to comment Share on other sites More sharing options...
tysparks81 Posted June 26, 2023 Share Posted June 26, 2023 If you are just swapping bumpers it will fit. Both cars are EDM/JDM spec from the pics and the body panels are interchangeable. You should only need to swap the front bumper. If you are trying to use the washer headlights in your second pic you need the lines as well as the washer pump tank to make them work on your car. 1 #LGTSTi is still cheaper and nicer then an equal year wrxsti Follow my 2007 Spec B. Build here Link to comment Share on other sites More sharing options...
m sprank Posted June 26, 2023 Share Posted June 26, 2023 @tysparks81 has a jdm front end conversion on his SpecB. He probably knows from experience. Link to comment Share on other sites More sharing options...
