Cegueta Posted June 11, 2023 Share Posted June 11, 2023 Hi everyone, Here is a little of info! I have the traction off light on in my dash plus the tpms light. When I read the codes on the dash (codes read with light switch and trip reset button) I don't have any code. It's showed P---- and C----. But when I pulled out the codes with a obd2 bluetooth driver reads the following codes: C0071, C0026, C0028 and 26. I fixed code 26 already (passenger airbag indicator). When I erase the code still showing up even that the airbag light on my dash went off. My questions are: 1. Do I need an special scanner to erase the codes since with mine is no working? 2. Why I cant see the codes on my odometer? 3. Are those are stored codes? Thanks in advance for any help!!! Link to comment Share on other sites More sharing options...
KZJonny Posted June 11, 2023 Share Posted June 11, 2023 (edited) Using the dash code reader, you use the odo reset ‘button’ to cycle through the codes groups. Apologies if you’ve already done that, but mine will also flash the P—-, but pushing the button twice bring up my actual C DTCs. They flash in order, and repeat. Currently trying to diagnose out C0109 C0111 and C0101. Edited June 11, 2023 by KZJonny Link to comment Share on other sites More sharing options...
Cegueta Posted June 11, 2023 Author Share Posted June 11, 2023 Thanks for your help. I did that is showing me C----. Like no codes for C group. Link to comment Share on other sites More sharing options...
