Andrew765 Posted June 5, 2023 Share Posted June 5, 2023 Hey guys, I'm looking to replace the differential fluid on my 2014 legacy 3.6r. I am unsure what hex socket size I need and I also need the drain plug gasket but I can't find the part anywhere. If anyone can help me out with this it would be greatly appreciated. Thanks! Link to comment Share on other sites More sharing options...
Andrew765 Posted June 5, 2023 Author Share Posted June 5, 2023 I am also confused to the fact that my car model has 3 different differential types and I have no clue what my car has. Link to comment Share on other sites More sharing options...
creep_nu Posted June 5, 2023 Share Posted June 5, 2023 i haven't changed my diff fluid in a while, but aren't the drain plugs 3/8 square? like, the square drive on a 3/8 ratchet takes em off? Link to comment Share on other sites More sharing options...
DrD123 Posted June 9, 2023 Share Posted June 9, 2023 Front differential takes a torx T70 and the gasket should be p/n 803926090. The rear differential uses a 3/8 square drive as creep_nu said - there is no gasket on either the drain or fill for the rear differential (make sure you can get the fill plug out before you pull the drain plug!) Link to comment Share on other sites More sharing options...
silverton Posted June 9, 2023 Share Posted June 9, 2023 (edited) Front diff is a T70, rear diff is either a 1/2" square, not 3/8ths, or a H10...or 12? pretty sure the 1/2" square is gonna be on the four cylinder models though, the six cylinder has a beefy rear diff and is likely the H10..or 12 but I really wanna say it's a 10.. brain fried I can't remember. Edited June 9, 2023 by silverton Link to comment Share on other sites More sharing options...
