jagoulet Posted February 24, 2023 Share Posted February 24, 2023 hi! I have a 2009 Impreza hatchback with regular 2.5 L motor. The washer pump for the front wipers does not work. Wipers work. Fuse OK. Rear pump works, rear wiper works. Where is the pump for the front? (front wheel well?) Anything I need to know . . don't be bashful! thanks! John Mass Link to comment Share on other sites More sharing options...
silverton Posted February 25, 2023 Share Posted February 25, 2023 The pump for the front sprayer is right next to the pump for the rear sprayer, behind the left front wheel well liner. Link to comment Share on other sites More sharing options...
jagoulet Posted February 25, 2023 Author Share Posted February 25, 2023 thank you! much appreciated. john Link to comment Share on other sites More sharing options...
jagoulet Posted February 28, 2023 Author Share Posted February 28, 2023 I got the wheel well opened up and good view of the washer pumps. Bottom line: if I swap the leads (front-rear) then the front pump works fine when I rotate the control arm on the steering column. Hence it seems there is no power being provided. The wipers come on fine with either setup. Do I need a new switch on the steering column? Swapping the leads got me thru the annual inspection, so I have plenty of time now. Link to comment Share on other sites More sharing options...
silverton Posted February 28, 2023 Share Posted February 28, 2023 I would suspect the switch, it's very rarely the wiring. 1 Link to comment Share on other sites More sharing options...
jagoulet Posted February 28, 2023 Author Share Posted February 28, 2023 I agree . . . would rather replace the switch than go on a wire adventure hunt. thanks for your thoughts . . . Link to comment Share on other sites More sharing options...
