Kayaker Posted November 9, 2022 Share Posted November 9, 2022 Sometimes when I use auto-up the window closes and then goes back down half way. It won't go up again unless it goes down first. The standard reset procedure usually fixes the problem right away but why is this happening in the first place? Do I need to adjust or replace something? Link to comment Share on other sites More sharing options...
silverton Posted November 10, 2022 Share Posted November 10, 2022 I believe the window seal at the top gets swollen and needs to be replaced. Link to comment Share on other sites More sharing options...
ammcinnis Posted November 10, 2022 Share Posted November 10, 2022 This is a fairly common complaint. Others have reported good success simply cleaning the window channels. That would be a good (and inexpensive) place to start. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
subaru-tech Posted December 16, 2022 Share Posted December 16, 2022 We see this problem all the time at the dealer, especially with smokers. The window run gets dirty. I soak a rag in brake clean and use a flat head screw driver to clean the channel. Sometimes I have to put so.e lube on the window run. Link to comment Share on other sites More sharing options...
