trunks Posted October 30, 2022 Share Posted October 30, 2022 I have all 8 for the turbo and avcs. Was cleaning up and found a random fine threaded banjo under the engine stand. It's the same size as the turbo but fine threaded. The hole is slightly larger as well. Can someone please help me out? I'm constantly wrenching but since it's banjo I'm a bit concerned. 20221030_001037.heic Link to comment Share on other sites More sharing options...
silverton Posted October 30, 2022 Share Posted October 30, 2022 I think there are only 7 banjos? two each for the avcs lines, a banjo in the top of the turbo, and then the two banjo's for the coolant lines. Link to comment Share on other sites More sharing options...
trunks Posted October 30, 2022 Author Share Posted October 30, 2022 There's a turbo oil feed on the back of the head too. I'm dumbfounded by it. I looked over my Saab this morning hoping it was missing one on the ventilation system but no luck. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 30, 2022 Share Posted October 30, 2022 Here's the back of the head, on my 05. The front side of driver's side has the same filtered banjo set up. Are you asking about a Subaru or a Saab, what year car ? 60c4bca40385abf60f9bc68bbe2ef4edoil feed banjos.webp 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
trunks Posted October 30, 2022 Author Share Posted October 30, 2022 (edited) It's a 2006 Spec B. I recently was working on my 9-5 in the next stall so just thought maybe. I've read all Subaru banjos are course thread. Maybe it was just stuck in the engine stand or cherry picker for a few years and finally fell out Edited October 30, 2022 by trunks Link to comment Share on other sites More sharing options...
silverton Posted October 30, 2022 Share Posted October 30, 2022 If you don't have any obviously open holes in your engine, I would suspect it's an extra from a previous project. Link to comment Share on other sites More sharing options...
