SleeperScoob Posted August 25, 2022 Share Posted August 25, 2022 (edited) SOLD Year, Make and Model: 2005 Subaru Legacy GT Wagon 5MT (non-limited) Color: Brilliant Silver Metallic (BSM) Miles: ~106,000 Transmission: 5 Speed Manual Title: Clear - No accidents Lien: None Location: Bethesda, MD VIN: 4S3BP686556373636 Seller's email address: SOLD Asking Price: $4,000 FIRM $6,500 $7,000 (Must have cash in hand, will not accept PayPal)(SEE LATEST REPLY REGARDING PPI FINDINGS)Purchased from previous user "rexster" in 2014 @ 55k miles. I'm finally selling my 05 LGT Wagon 5MT that I've owned for 8 years. I've recently purchased a new AWD vehicle with plenty of cargo space and I no longer need this little gem. It's been a fun ride, daily driving it to work and loading it up with luggage for trips. Nowadays, it just sits in front of my house and I only drive it occasionally to keep the battery topped up and keep the fluids, brakes, and tires in check. It's time for a new home to someone who enjoys these cars and can give it the bit of TLC it needs. The exterior is about a 6/10; the paint is overall in decent shape, but it has some dents and scratches and the hood scoop is peeling, typical of a car from 2005. The interior is about an 8/10, only a few minor cosmetic issues. The previous owner installed an amp in the trunk and a rudimentary single-din head unit in the cubby space with AUX capability. He also replaced the speakers, but the rear speakers do not work. The Good: - Runs and drives great, it's never left me stranded. - Doesn't leak or burn anything. There is always a slight smell of burnt oil in the exhaust, but that is typical of a catless EJ25X and I never have to top it up between changes. - No body rust whatsoever. - The black cloth interior is still 8/10. All seats are in great shape. - A/C blows cold. - Has AUX capability. - All bulbs in working order.- A station wagon with 300whp. - Brand new brake pads and rotors Front and Rear. The Not-so-good: - Clunk from the front suspension at low speeds over uneven roads. - Rear window motors function fine, but squeal. - Undercarriage is pretty surface-rusty. - Rear speakers do not work. - Driver side mirror turn signal lens is cracked, but doesn't induce moisture. Been that way since I got the car.Cosmetic Issues:- Was in a minor hailstorm a few years ago and has a number of small dents in the roof and hood. I hardly notice them unless I'm really looking. No glass was damaged. PDR would have to go over the car. - Hood scoop paint is peeling off. - Passenger side fender and hood alignment is slightly off and has small dent from hood dropping on tool hanging out of hood. - Rear bumper has a scuff from someone tapping it in a parking lot. - Rear windshield has a small white mark / line at the top (a white jack handle's doing) - Black paint on trim beneath front windows is peeling away, Plasti-dip would easily take care of this. Relevant Maintenance Items: - Oil Changed with Rotella T6 5w40 every 3,000 miles or fewer during my ownership - Transmission oil and Rear Diff oil changed every 30,000 miles with Extra-S either by myself or Subaru Dealership - Timing Belt, pulleys, and water pump replaced @ 65k miles by Andrewtech - Valves adjusted / valve buckets replaced by Andrewtech - Valve Cover Gaskets replaced - Both rear wheel bearings have been replaced @ 80k miles - Radiator replaced with OEM unit @ 90k miles - New OEM front O2 sensor - New OEM MAP sensor - New ignition coils and plugs - A/C recharged at Subaru Dealership last year and still blows cold - New Battery - New negative battery terminal- Brand new brake pads and rotors Front and Rear. MODS:Engine: Tuned by Jermaine @ TurboXS (retuned in 2021) Made 305whp / 349wtq on their Dynapack on 93 octane Installed @ ~90k Miles by Andrewtech: VF52 from a 2010 WRX (had ~25k miles when pulled) Invidia Catless Downpipe Catless Mid-pipe (from an STI, no EGT sensor) Perrin 3" Resonated Exhaust to Fast Motorsports mufflers Perrin Inlet Hose Grimmspeed 3-port EBCS Grimmspeed TMIC GFB Respons Hybrid Recirc/BOV DW 850cc Side-Feed Injectors DW 65c Fuel Pump Type-N Motor Mounts Type-N Pitch-Stop Mount Removed AVCS oil screens (were clean when they came out) Innovate Motorsports Wideband A/F gauge Defi Oil Pressure Gauge Transmission: (All installed @ ~90k miles by Andrewtech) Stage 2 South Bend Clutch ACT Streetlite Single Mass Lightweight Flywheel (13lbs) Type-N Transmission mount Whiteline Positive Shift Kit Suspension: (Installed by Previous Owner) Bilstein Yellow Struts (Front / Rear) STI Pink Springs (Front / Rear) STI Lower Control Arm Bushings (Front) Whiteline Sway Bars (Front / Rear) Aftermarket Sway Bar Endlinks (Front / Rear) Exterior: Enkei RPF1 Wheels (7.25" x 17) DDM Tuning 5000K HID Kit (Slim) JDM Taillights with gen 2 LED bulbs + LED turn signal relay to remove hyperflash 50% Window Tint (very light) Grimmspeed License Plate Frame Uninstalled parts that come with the car: Stock wheels with Blizzak Tires (10 miles on them, if that. It never snows here anymore) Used R-Rev front lip (purchased but never installed) Stock Downpipe Stock Mid-pipe + EGT Sensor Stock Mufflers (flanges should be replaced) Stock Sway Bars Grimmspeed Turbo Heatshield (Metal) Edited August 6, 2023 by SleeperScoob SOLD Link to comment Share on other sites More sharing options...
SleeperScoob Posted August 25, 2022 Author Share Posted August 25, 2022 (edited) Pics of interior, engine bay, and undercarriage coming. Edited September 15, 2022 by SleeperScoob Added engine bay and undercarriage images 1 Link to comment Share on other sites More sharing options...
SleeperScoob Posted September 15, 2022 Author Share Posted September 15, 2022 Emails and PMs replied to. Link to comment Share on other sites More sharing options...
SleeperScoob Posted September 15, 2022 Author Share Posted September 15, 2022 (edited) Added engine bay and undercarriage pics! Yes, those header heatshields are still holding on somehow. They can certainly be removed, the headers don't look like that lol. Got it out for a little TLC today, and still dry as a bone! Doesn't leak a drop. Edited September 15, 2022 by SleeperScoob Link to comment Share on other sites More sharing options...
SleeperScoob Posted October 22, 2022 Author Share Posted October 22, 2022 Just went ahead and installed brand new brake pads and rotors all around. Centric rotors and Akebono ceramic premium pads (tired of dust). Link to comment Share on other sites More sharing options...
robbenfred50 Posted October 23, 2022 Share Posted October 23, 2022 Still available? Can i pm Link to comment Share on other sites More sharing options...
SleeperScoob Posted October 23, 2022 Author Share Posted October 23, 2022 1 hour ago, robbenfred50 said: Still available? Can i pm Feel free to PM me, still available. Link to comment Share on other sites More sharing options...
TwoTone Posted October 23, 2022 Share Posted October 23, 2022 Any interior pictures? Link to comment Share on other sites More sharing options...
SleeperScoob Posted October 27, 2022 Author Share Posted October 27, 2022 On 10/23/2022 at 6:39 PM, TwoTone said: Any interior pictures? Unfortunately I just haven't gotten around to taking any, but the interior is in quite solid shape. Feel free to PM me if you'd like to begin a commentary. Thanks! Link to comment Share on other sites More sharing options...
SleeperScoob Posted January 20, 2023 Author Share Posted January 20, 2023 (edited) Huge Price Drop to $4000. Had a Pre-Purchase Inspection (PPI) performed at Yates-Auto in Airpark (Gaithersburg, MD) (Andrew Yates, founder of Andrewtech). "Compression: ~125psi on all cylinders, Leakdown less than 6% on all cylinders. Verified correct cam timing." The engine is sound. Transmission is sound. Needs suspension soon (rusty) and oil filter housing gasket is starting to weep. Bad news from PPI (co-diagnosed by Andrew and Jermaine from TurboXS): The car needs a top-feed fuel system conversion. Yates quoted this around $2000 total (parts + labor) for fuel lines, fuel rails, ID 1000 injectors, etc. The DW 850cc side-feed injectors are inconsistent on the rich side. On some WOT pulls, the injectors will throw the right amount of fuel, and the injectors will throw too much fuel on other pulls. A/F has never been lean. No boost or vacuum leaks were found anywhere. This does not really affect daily-drivability. I've had this fuel system on the car for almost a decade, but there is no longer support for side-feeds and top-feeds are much more reliable. Edited January 20, 2023 by SleeperScoob 2 Link to comment Share on other sites More sharing options...
m sprank Posted February 5, 2023 Share Posted February 5, 2023 If no buyers found, I am looking for a donor to build into a full track car. Wagons preferred for their wieght bias. My offer will be lower than current asking price as build will most likely run cost of car when new. Link to comment Share on other sites More sharing options...
Catabaru Posted February 5, 2023 Share Posted February 5, 2023 I know where your car is , I am local to you. Wish I have extra cash so my ABP wagon has parking buddy. GLWS 1 Link to comment Share on other sites More sharing options...
m sprank Posted February 19, 2023 Share Posted February 19, 2023 Is the car still for sale? Link to comment Share on other sites More sharing options...
SleeperScoob Posted February 19, 2023 Author Share Posted February 19, 2023 (edited) Still for sale. Just drove it again yesterday, runs and drives like a dream. If I can't get near the current asking price, it's worth more to me to just keep as a spare / fun car. It's still dependable, rowdy, and hauls stuff for me. It always fires right up and drives without a fuss. I've got around $16,000 in it (including what I paid for it), and there's very little mechanically wrong with it. I will not be letting it go for pennies. If you're looking for a dirt cheap roller to do a build / swap on, this is not it. Edited February 19, 2023 by SleeperScoob 3 Link to comment Share on other sites More sharing options...
m sprank Posted February 20, 2023 Share Posted February 20, 2023 Email sent. Link to comment Share on other sites More sharing options...
m sprank Posted February 21, 2023 Share Posted February 21, 2023 Serious potential cash buyer awaiting email response. $4K OBO is a price worthy of checking out the car in person. Link to comment Share on other sites More sharing options...
SleeperScoob Posted February 21, 2023 Author Share Posted February 21, 2023 2 hours ago, m sprank said: Serious potential cash buyer awaiting email response. $4K OBO is a price worthy of checking out the car in person. Messaged you, thanks. Car is still for sale. 1 Link to comment Share on other sites More sharing options...
m sprank Posted February 21, 2023 Share Posted February 21, 2023 Replied. Thanks. Link to comment Share on other sites More sharing options...
cal71919 Posted March 6, 2023 Share Posted March 6, 2023 Reminds me of my wagon I deeply regret selling. Sure hope my tdi sells soon, I'll be all over this. 2 Link to comment Share on other sites More sharing options...
bobglaub Posted June 24, 2023 Share Posted June 24, 2023 still available? Link to comment Share on other sites More sharing options...
SleeperScoob Posted July 4, 2023 Author Share Posted July 4, 2023 On 6/24/2023 at 10:51 AM, bobglaub said: still available? Yep! Link to comment Share on other sites More sharing options...
DK76 Posted July 6, 2023 Share Posted July 6, 2023 PM'd Link to comment Share on other sites More sharing options...
SleeperScoob Posted July 6, 2023 Author Share Posted July 6, 2023 Replied! Interior pics since there has been some new-found interest on the car. You will see some oil stains on the trunk carpet, some mulch clippings, and the car could use a deep detail. All seats, fabric, and dash are intact, and no excess wear on the driver's seat bolster, just a small ripple. There are scuffs and scratches on paneling here and there, as the car has been a daily driver for 15 years. $4,000 is FIRM; if you are not willing to pay this, please do no bother. Do not show up with "All I have is $3,000 on me" and waste both of our time. This price is already low enough, IMO. Thanks everyone! Link to comment Share on other sites More sharing options...
anon_az Posted July 29, 2023 Share Posted July 29, 2023 PM'd Link to comment Share on other sites More sharing options...
SleeperScoob Posted July 30, 2023 Author Share Posted July 30, 2023 Pending sale. 2 Link to comment Share on other sites More sharing options...
