Gars05 Posted June 11, 2022 Share Posted June 11, 2022 Hey guy's on my 2005 2.5i non-turbo wagon, I'm beginning to notice the car stumble, or miss more than usual, only when the A/C is on and at idle. When this happens, it really causes the car to momentarily shake...almost like a hard misfire or something, and then she quickly idles fine. This does not happen when the A/C is off. Could my compressor be on its way out and starting to seize up or something? As far as AC temp, for the most part she blows cold. I would not describe it as a "consistent cold" but its comfortable. The car has 289k miles. In late 2019, I did change out the condenser, dryer, expansion valve, and found a nice used compressor. My son hit a deer and so I had to replace several items. Thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted June 11, 2022 Share Posted June 11, 2022 Not sure if the service manual will help, http://people.csail.mit.edu/ilh/vacation/ Did you do the change out yourself or have it done ? You might want to take it to a repair shop and have them check it out before the AC clutch has a real issue if you think that's what it could be. Is there any other sound, then the "click" when you cycle the AC on/off ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
relative4 Posted June 11, 2022 Share Posted June 11, 2022 What is your idle trim %? Link to comment Share on other sites More sharing options...
Gars05 Posted June 12, 2022 Author Share Posted June 12, 2022 Not sure if the service manual will help, http://people.csail.mit.edu/ilh/vacation/ Did you do the change out yourself or have it done ? You might want to take it to a repair shop and have them check it out before the AC clutch has a real issue if you think that's what it could be. Is there any other sound, then the "click" when you cycle the AC on/off ? I changed it all out myself and had a shop recharge the system. Link to comment Share on other sites More sharing options...
Gars05 Posted June 12, 2022 Author Share Posted June 12, 2022 What is your idle trim %? Don't know how to do this. I do have the Torque App so would this help? Link to comment Share on other sites More sharing options...
silverton Posted June 12, 2022 Share Posted June 12, 2022 Torque will read your short and long term trims no problem. It does sound like there's a bit of extra drag in your compressor, or the tensioner pulley. Link to comment Share on other sites More sharing options...
Gars05 Posted June 13, 2022 Author Share Posted June 13, 2022 Torque will read your short and long term trims no problem. It does sound like there's a bit of extra drag in your compressor, or the tensioner pulley. I recently replaced the pully and also checked and adjusted the air gap on the clutch. Link to comment Share on other sites More sharing options...
relative4 Posted June 13, 2022 Share Posted June 13, 2022 Don't know how to do this. I do have the Torque App so would this help? Yes, you want the bank 1 Long Term Fuel Trim and Short Term Fuel Trim. Link to comment Share on other sites More sharing options...
