JoeInOregon Posted March 3, 2022 Share Posted March 3, 2022 As expected all the vacuum hoses on the underside of my intake manifold are petrified and cracking in half. In my attempt to remove this on it snapped the nipple right off. I wonder how sensitive this port is to diameter , was hoping I could just tap or epoxy a new nipple on. Thanks Sent from my Pixel 3a using Tapatalk Link to comment Share on other sites More sharing options...
JoeInOregon Posted March 3, 2022 Author Share Posted March 3, 2022 Welp help please Sent from my Pixel 3a using Tapatalk Link to comment Share on other sites More sharing options...
whitexc Posted March 3, 2022 Share Posted March 3, 2022 Does that whole piece possibly come out of the intake....maybe replace it? If not, I would find a male barbed fitting that you could thread in there and put some epoxy on it (not a lot) right before you send it. Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
kzr750r1 Posted March 3, 2022 Share Posted March 3, 2022 That port should not have a bother with slightly different size. You can likely get some brass or stainless hardline and epoxy it in there. I would get something slightly larger than the hole ID. Drill in a step. start seating the hard line... Schmoo on some epoxy or JBweld then press the rest of the way. Link to comment Share on other sites More sharing options...
JoeInOregon Posted March 4, 2022 Author Share Posted March 4, 2022 Does that whole piece possibly come out of the intake....maybe replace it? If not, I would find a male barbed fitting that you could thread in there and put some epoxy on it (not a lot) right before you send it. Sent from my SM-G996U using TapatalkIt looks like it comes out but I'm not sure nor could I find a replacement Sent from my Pixel 3a using Tapatalk Link to comment Share on other sites More sharing options...
JoeInOregon Posted March 4, 2022 Author Share Posted March 4, 2022 That port should not have a bother with slightly different size. You can likely get some brass or stainless hardline and epoxy it in there. I would get something slightly larger than the hole ID. Drill in a step. start seating the hard line... Schmoo on some epoxy or JBweld then press the rest of the way.That's what I was hoping, best I could tell it is the exit of the purge valve bringing fuel vapor into the intake Sent from my Pixel 3a using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted March 4, 2022 Share Posted March 4, 2022 (edited) I'm wondering why you couldn't T the hose into another hose, and plug that broken nipple. There is a picture of the vacuum hose set up here some where, it's also in the back of the service manual. http://people.csail.mit.edu/ilh/vacation/ Edited March 4, 2022 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JoeInOregon Posted March 5, 2022 Author Share Posted March 5, 2022 (edited) I'm wondering why you couldn't T the hose into another hose, and plug that broken nipple. [ATTACH]295374[/ATTACH] [ATTACH]295375[/ATTACH] There is a picture of the vacuum hose set up here some where, it's also in the back of the service manual. http://people.csail.mit.edu/ilh/vacation/Thank you that is a good pic I was wondering the same thing , my only thought was that as it's vapor return it should be independent. Also what I did notice is that port is connected to a "straw' that terminates about dead center inside of the manifold. I will get a pic tomorrow when I'm near the car. Sent from my Pixel 3a using Tapatalk Edited March 5, 2022 by JoeInOregon Link to comment Share on other sites More sharing options...
JoeInOregon Posted March 7, 2022 Author Share Posted March 7, 2022 This is a shot of the other end of the nipple in question Sent from my Pixel 3a using Tapatalk Link to comment Share on other sites More sharing options...
bergs Posted March 7, 2022 Share Posted March 7, 2022 I broke that same fitting on an 05 I used to own. Long story short I bought a replacement intake manifold from a member here. Link to comment Share on other sites More sharing options...
All_talk Posted March 9, 2022 Share Posted March 9, 2022 I suspect the position of that "straw" is somewhat important in distributing the fuel vapor equally to all cylinders, teeing into another line may not. I'm also guessing that the small diameter of the straw works as an orifice to control flow at cruise vacuum (high), when the solenoid is open. I would try and repair the nipple at that location, or look for a good used manifold. Link to comment Share on other sites More sharing options...
