Chadw79 Posted January 13, 2022 Share Posted January 13, 2022 (edited) I’m installing a (my97-98 Impreza)Transmission in my 97 legacy. Here’s the issue I’ve run into. The lower starter stud on my original trans was threaded into the bell housing, and the new transmission has a unthreaded hole. What can I do to solve this problem? Edit: The hole is bigger in diameter than the threaded stud is already. Edited January 15, 2022 by Chadw79 Adding info about the problem Link to comment Share on other sites More sharing options...
doublechaz Posted January 13, 2022 Share Posted January 13, 2022 Get a regular tap and a bottoming tap and thread the hole? If it's a through hole and you haven't mounted it you can skip the bottoming tap. Go to the dealer and find out if it has a press in stud for that application and pay them $50 for a $2 part. That's all I can think of. Link to comment Share on other sites More sharing options...
silverton Posted January 13, 2022 Share Posted January 13, 2022 either thread the hole, 10x1.25, or deal with one bolt in the starter... Link to comment Share on other sites More sharing options...
wtdash Posted January 14, 2022 Share Posted January 14, 2022 You're 100% sure of the year on that Trans? Sounds like a Phase 2 trans to me. What's the TZxxxxxxxx code on the trans = to verify year/application? Link to comment Share on other sites More sharing options...
Chadw79 Posted January 15, 2022 Author Share Posted January 15, 2022 TY754VA1AA I thought it was a MY97-98, now looking again it’s a MY99-01 transmission. Does that make it a phase 2 transmission? Other than the gearing difference it’ll still work correct? Link to comment Share on other sites More sharing options...
wtdash Posted January 16, 2022 Share Posted January 16, 2022 5-speed should work and be the same FD ratio = 3.9. Check this chart: http://www.gearhack.com/myink/ViewPage.php?file=docs/Subaru%20Transmission%20Chart As noted above you can usually get away w/using just the one bell-housing bolt. I was originally thinking Automatic and that wouldn't work. Link to comment Share on other sites More sharing options...
