MarceraB16 Posted December 27, 2021 Share Posted December 27, 2021 Can someone please help me? I bought a 05 Legacy GT almost a year ago and for some reason I cannot pull any live data or codes off my OBD2 port. I even bought a cobb access port, and I still cannot pull anything. I had the Subaru dealer look at it and they could pull up data on the laptop and their cheap handheld tool. So, they thought maybe my ECM had been replaced at some point and the vin wasn't burned into it... So, they checked it for me, and it was. They told me they have no idea why it won't work. At this point I'm stumped too, my mechanic friends touch screen tool couldn't pull anything, my cheap tool and Bluetooth tool couldn't either and neither can the cobb access port I just bought. It won't even power on when I plug it in but does turn on if plugged into a laptop. If someone is near Rochester NY and can help or someone can help remotely that would be greatly appreciated. Please help.... Link to comment Share on other sites More sharing options...
Max Capacity Posted December 27, 2021 Share Posted December 27, 2021 I'd suggest you reach out to Dave at Cyrotuning, you can reach his info from the third post here, https://legacygt.com/forums/showthread.php/finally-got-cryotuned-youi-194437.html You may have a issue with your OBD2 port. I seem to recall a couple of people having to replace it in the past. Maybe search google for replacing OBD2 port on a 2005 ... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
whitexc Posted December 27, 2021 Share Posted December 27, 2021 And check ground wires. Grounds can cause all sorts of issues. Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted December 27, 2021 Share Posted December 27, 2021 I'll assume you mean the two from the under the engine to chassis and or the ground bar by the brake booster and throttle body. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MarceraB16 Posted December 27, 2021 Author Share Posted December 27, 2021 Thank you all I sincerely appreciate your help. I'll check the ground and contact cryotuning as well Link to comment Share on other sites More sharing options...
JoeInOregon Posted December 30, 2021 Share Posted December 30, 2021 Had a very similar problem , end up charging my battery to completely full on external charger, plugging in the AP and wiggling lol it eventually came on, have not removed the odb cord sense Sent from my Pixel 3a using Tapatalk Link to comment Share on other sites More sharing options...
Boddah067 Posted January 2, 2022 Share Posted January 2, 2022 Most cars have the OBD2 port powered on the same circuit as the 12v/cig lighter. Check the fuse before you dig in any further. Especially if anyone dropped a coin in the 12v socket. Link to comment Share on other sites More sharing options...
