prezton Posted November 15, 2021 Share Posted November 15, 2021 The scrapyard I work at has a '14 wrx that came in, with engine and transmission at about 110k. I purchased my '09 for about 5k last year, and long story short. The engine and trans are no good . My question is, will the '14 wrx motor and trans fit in the 09 legacy GT? If so, what changes would I have to make? I did do some digging at the scrapyard and only saw that the engines have different fuel injection. (I think the WRX has spray.) Thanks! Link to comment Share on other sites More sharing options...
Max Capacity Posted November 18, 2021 Share Posted November 18, 2021 See here for replies, https://legacygt.com/forums/showthread.php/engine-and-trans-swap-into-09-lgt-287152.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
