Zac88 Posted August 20, 2021 Share Posted August 20, 2021 Has anyone had this happen? I have a primitive racing skid plate and I guess over 10 years of salt and rust, the bolts broke off inside the rad support. Has anyone encountered this and found a fix? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 20, 2021 Share Posted August 20, 2021 Is there a picture of the area ? Don't feel like walking out my car to look. Can you cut a hole on either side and reach around from there ? Then just fill the hole with sealant. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted August 20, 2021 Share Posted August 20, 2021 The 2 brackets on the bottom that catch the bottom of the radiator with grommets? If you are talking that entire bottom piece that needs to be done by a body shop, it will require cutting and welding I believe. Link to comment Share on other sites More sharing options...
