comotiger Posted July 20, 2021 Share Posted July 20, 2021 Hi folks, I removed the front bumper on my son's 2017 Legacy to fix some dents. I found this open connector on the driver's side. What does it connect to? The car runs fine and all of the lights and other electricals are working normally as well. Thanks for any insights. Best wishes, AC Link to comment Share on other sites More sharing options...
Code Posted July 20, 2021 Share Posted July 20, 2021 Intercooler sprayer. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
comotiger Posted July 20, 2021 Author Share Posted July 20, 2021 Intercooler sprayer. Thanks! Is this a problem to resolve? Do all trim levels have the sprayer? What does it do? Is it needed for both the 4 and 6 cylinder engines? Mine is 4 cyl. Link to comment Share on other sites More sharing options...
comotiger Posted July 20, 2021 Author Share Posted July 20, 2021 Thanks! Is this a problem to resolve? Do all trim levels have the sprayer? What does it do? Is it needed for both the 4 and 6 cylinder engines? Mine is 4 cyl. OK, I looked it up and the sprayer is only needed in models with the turbocharged engine, and even then appears to be an option. Why is this wiring installed in a base 2.5L engine car? In any case, it's a relief to know that nothing is wrong with my car. Link to comment Share on other sites More sharing options...
ronemus Posted July 20, 2021 Share Posted July 20, 2021 Could it be for the grille shutter? Link to comment Share on other sites More sharing options...
comotiger Posted July 20, 2021 Author Share Posted July 20, 2021 (edited) Could it be for the grille shutter? That's interesting! I would have guessed that active grille shutters would be found only in high-end cars, but I would be wrong! 2017 Legacy 2.5i cars have the active shutters that close for improved fuel economy at highway speeds. https://drive.subaru.com/sum16-legacy-fuel-economy The connector appears to be on the driver's side, so this seems more plausible than the intercooler sprayer. http://www.sulegacy.com/removal-1762.html If the shutter was disconnected (and inactivated) in a previous repair, it probably doesn't affect performance much. Except that I hope it is stuck in the open position to allow maximum cooling for daily in-town driving. I hope I can spot this without having to take the bumper off again. Edited July 20, 2021 by comotiger Link to comment Share on other sites More sharing options...
Grnlantern1 Posted July 20, 2021 Share Posted July 20, 2021 They would not put that connector there for a Intercooler Sprayer when our cars do not have turbo.. Come on.. Help this guy out.. I have a 3.6 so not sure if its for the shutter control.. Sent from my SM-G988U using Tapatalk Link to comment Share on other sites More sharing options...
XT-sub Posted July 20, 2021 Share Posted July 20, 2021 (edited) I found this open connector on the driver's side. What does it connect to? The car runs fine and all of the lights and other electricals are working normally as well. Seeing how short that wire loom is between the plug & the piece of black PVC tape, it has to be somewhere close to that plug. My first thought was it was either for the front or the rear washer motor. I’ve got a photo of our previous 2016 Liberty 3.6R in that area & it shows a grey plug with a green & a brown wire that isn’t connected. But our Aussie spec cars are wired different to the US cars & have some different features. Compared to my Liberty photo, the wiring in the photo you posted looks somewhat messy – has someone re-hashed & taped it up, or is that how the US Legacys are? If it has been re-hashed & taped up, that plug could be in the wrong location. I had a look in the 2015 Outback/Legacy FSM for anything I could find in that LHS area with the following results (where a wire colour has a slash [e.g. G/B], the first colour is the main colour & the second colour is a stripe): (1). Active grill shutter wire colours (only on the 2.5i); red/black (R/B), white (W) & black (B). (2). Front washer motor wire colours; green/black (G/B) & brown/red (BR/R). (3). Rear washer motor wire colours; brown (BR) & green (G). (4). Front LH fog light wire colours; With SRF = black (B) & red/yellow (R/Y). Without SRF = black (B) & red/blue (R/L). (5). Horn LH wire colour: black/red (B/R). (6). Front LH turn signal wire colours; black/green (B/G) & black (B). (7). There is also a bulkhead wiring connector somewhere in that area but it only shows a single black wire in a 4-pole connector. This could be tied into the radiator fan circuit. I’ve attached a cropped & size reduced photo of a gen5 Outback (similar to gen6 Legacy) I grabbed some time ago from the subaruoutback.org forum (can’t remember who posted it) & it shows two grey connectors in that area. They appear to go to the front washer motor & the rear washer motor. Edit: After downloading your photo & zooming in I'm now fairly certain that connector is for the rear washer pump motor that the Legacy doesn't have (if it was fitted it would be fitted to the washer bottle in the area directly behind & above that connector). On my Liberty photo & also on the Outback photo I attached it shows a pump motor in that location. On my Liberty the second pump is for the headlight washers that the North American vehicles don’t have, & on the attached Outback photo the second pump is for the rear hatch window washer which the Legacy & Liberty don't have. Gen5 Outback front left side Edited July 20, 2021 by XT-sub More information added at the edit. Link to comment Share on other sites More sharing options...
Code Posted July 20, 2021 Share Posted July 20, 2021 Intercollegiate sprayer was a joke BUT I bet all legacy get the same harness, regardless of trim level and options selected. I would ignore it. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
comotiger Posted July 20, 2021 Author Share Posted July 20, 2021 Seeing how short that wire loom is between the plug & the piece of black PVC tape, it has to be somewhere close to that plug. My first thought was it was either for the front or the rear washer motor. I’ve got a photo of our previous 2016 Liberty 3.6R in that area & it shows a grey plug with a green & a brown wire that isn’t connected. But our Aussie spec cars are wired different to the US cars & have some different features. Compared to my Liberty photo, the wiring in the photo you posted looks somewhat messy – has someone re-hashed & taped it up, or is that how the US Legacys are? If it has been re-hashed & taped up, that plug could be in the wrong location. Yes, the tape on many of the wires was wearing out and beat up. The car had a left front accident when very new (<4000 miles) that had been fixed. So a lot of the re-taping could reflect the repair work. Everything runs like a charm so I am not concerned by the worn wiring. I did re-tape some of the bundles before re-installing the bumper. I’ve attached a cropped & size reduced photo of a gen5 Outback (similar to gen6 Legacy) I grabbed some time ago from the subaruoutback.org forum (can’t remember who posted it) & it shows two grey connectors in that area. They appear to go to the front washer motor & the rear washer motor. Edit: After downloading your photo & zooming in I'm now fairly certain that connector is for the rear washer pump motor that the Legacy doesn't have (if it was fitted it would be fitted to the washer bottle in the area directly behind & above that connector). On my Liberty photo & also on the Outback photo I attached it shows a pump motor in that location. On my Liberty the second pump is for the headlight washers that the North American vehicles don’t have, & on the attached Outback photo the second pump is for the rear hatch window washer which the Legacy & Liberty don't have. [ATTACH]292513[/ATTACH] Gen5 Outback front left side Your descriptions and photo also convince me that the connector is for the rear washer. It's right next to (below) the washer reservoir. Thanks, XT-sub! I still need to check out if the active grille shutters are open on my car. That motor and connecting wire shows up very nicely in your photo. Link to comment Share on other sites More sharing options...
ammcinnis Posted July 20, 2021 Share Posted July 20, 2021 (edited) I would have guessed that active grille shutters would be found only in high-end cars, but I would be wrong! 2017 Legacy 2.5i cars have the active shutters that close for improved fuel economy at highway speeds. FWIW, all MY 2015-2019 Legacys and Outbacks with the 2.5 H4 engine have the AGAS shutters; the 3.6 H6 models do not. The AGAS shutters are always closed 1) at temperatures below 37 degrees F, and 2) at road speeds above ~40 mph. Outside of those two conditions they may be open or closed, their position dynamically controlled by the ECM based on ambient temperature, coolant temperature, and road speed. (Source: Subaru tech training materials.) Edited July 20, 2021 by ammcinnis "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
iyalla Posted July 20, 2021 Share Posted July 20, 2021 I can confirm, I have a base 2.5i '18 and it has the AGAS shutters. Link to comment Share on other sites More sharing options...
aki334 Posted July 22, 2021 Share Posted July 22, 2021 (edited) fog lights, even if you do not have fog lights (base model) wiring is still there ambient temperature sensor could be another possibility, maybe you can check the reading on your dash Edited July 22, 2021 by aki334 Link to comment Share on other sites More sharing options...
Code Posted July 22, 2021 Share Posted July 22, 2021 At this point I would just add an intercooler and spray that mofo. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
ammcinnis Posted July 22, 2021 Share Posted July 22, 2021 ambient temperature sensor could be another possibility ... The ambient temperature sensor is on the other side of the car. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
comotiger Posted July 22, 2021 Author Share Posted July 22, 2021 fog lights, even if you do not have fog lights (base model) wiring is still there ambient temperature sensor could be another possibility, maybe you can check the reading on your dash My car has fog lights and they work fine. The vertically hanging wire with the just-visible brown connector in my photo is for the fog light. The ambient temp readings seem fine. I am pretty sure it's for the rear washer not found in the Legacy. Link to comment Share on other sites More sharing options...
aki334 Posted July 23, 2021 Share Posted July 23, 2021 (edited) that is gray connector b147 = rear washer motor 100% connector b44 is for horn LH and that is right above the b147 connector so leave it hanging reference: WI-468 and WI-469 from OEM repair manual or pages 7318 and 7319 from pdf I do not know if outbacks have rear wiper, so they are probably using same wiring for outbacks and legacies, just wild guess Pm me for info where to send me 6 pack Edited July 23, 2021 by aki334 Link to comment Share on other sites More sharing options...
XT-sub Posted July 24, 2021 Share Posted July 24, 2021 Pm me for info where to send me 6 pack Bad luck, you are a few days too late. It was sorted out here. I do not know if outbacks have rear wiper, ... The answer to that is in my same post. Link to comment Share on other sites More sharing options...
comotiger Posted July 24, 2021 Author Share Posted July 24, 2021 Pm me for info where to send me 6 pack Bad luck, you are a few days too late. It was sorted out Both of you have been a great help! Thank you! To celebrate, I bought a 6 pack and drank it all Link to comment Share on other sites More sharing options...
sense of nature Posted July 29, 2021 Share Posted July 29, 2021 If it was a wagon, it would be for the rear glass spray pump ... Link to comment Share on other sites More sharing options...
ehsnils Posted August 5, 2021 Share Posted August 5, 2021 At this point I would just add an intercooler and spray that mofo. Link to comment Share on other sites More sharing options...
ehsnils Posted August 5, 2021 Share Posted August 5, 2021 I do not know if outbacks have rear wiper, so they are probably using same wiring for outbacks and legacies, just wild guess My outback has one, but it's European spec. However I wouldn't be surprised if all have it since it's pretty much a standard feature today even though a reverse camera washer would make more sense today. Something I have seen on recent models. Link to comment Share on other sites More sharing options...
