bluesuby Posted June 19, 2021 Share Posted June 19, 2021 2005 LGT Wagon with 185,000 miles. Rear alignment could not be done with the eccentric adjustment bolts frozen by rust.Substantial repair cost includes replacement of the rear arms and related parts at a price of just under $2000. Question: With this many miles and alignment records showing less than one degree out of spec during past alignments, I was told just watch tire wear and any squirrelly behavior before doing anything. Tires look good and I'll be swapping for winter tires (in the Fall) I have had for several years. Annual mileage about 6000 in the future. Any words of wisdom or projections of how long I can do without adjustments or scrapping the car? Engine, clutch and brakes solid. No body damage or accident history. Thanks all. Link to comment Share on other sites More sharing options...
rhino6303 Posted June 19, 2021 Share Posted June 19, 2021 You could just cut the frozen bolts out and replace them. At the worst, you could cut the arms and bolts and replace both. Those arms aren't that expensive on their own. I also think you'd be fine leaving it and keeping an eye on tire wear. Link to comment Share on other sites More sharing options...
