VespaGTS Posted June 9, 2021 Share Posted June 9, 2021 My Fumoto oil drain plug had become loose and I was losing oil. Not sure how this could have happened? Maybe heat cycles and being overlooked for torque specs at oil change intervals? It went in originally at correct torque spec. Just saying it’s worth a look! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
norutah Posted June 10, 2021 Share Posted June 10, 2021 My Fumoto oil drain plug had become loose and I was losing oil. Not sure how this could have happened? Maybe heat cycles and being overlooked for torque specs at oil change intervals? It went in originally at correct torque spec. Just saying it’s worth a look! Sent from my iPhone using TapatalkIt's this in an OEM pan? Asking because I'm running a killer b pan and put the fumoto valve in the NPT thread instead of the straight thread hole Sent from my HD1925 using Tapatalk Link to comment Share on other sites More sharing options...
NORULZleggy Posted June 10, 2021 Share Posted June 10, 2021 This is why I use the EZ- drain valve. top notch and on all my cars. Never a problems. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 10, 2021 Share Posted June 10, 2021 All three of mine are still tight and not leaking. I'm wondering if it was operator error...I just installed all three of mine with an adjustable wrench, didn't use a torque wrench. That's why I went with Fumoto... LOL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Unko Posted June 10, 2021 Share Posted June 10, 2021 anyone ever tried the stahlbus? Link to comment Share on other sites More sharing options...
VespaGTS Posted June 12, 2021 Author Share Posted June 12, 2021 Stock oil pan. I have no idea why it was loose? Link to comment Share on other sites More sharing options...
norutah Posted June 12, 2021 Share Posted June 12, 2021 Stock oil pan. I have no idea why it was loose?Thanks, I checked mine for wetting and it was dry. My drain plug did need to be snugged a bit. Sent from my HD1925 using Tapatalk Link to comment Share on other sites More sharing options...
