NewSR Posted April 23, 2021 Share Posted April 23, 2021 2019 Subaru Legacy 2.5i Limited When I turn the HVAC system to "Off" AND I'm driving - heat still is being blown out of the center dash vents. Is this normal? In the old days [many years ago] when the heater/AC was turned off no air moved out of the vents [i.e., "Closed system"] If this condition is normal, do you have to keep the system on "Auto"?? Thanks in advance, Joe Link to comment Share on other sites More sharing options...
DougKelly20 Posted April 23, 2021 Share Posted April 23, 2021 Yes. Typically whatever it's set at before its turned off it will blow slightly when off. It seems like its just pass through air at that point. Nothing major. Link to comment Share on other sites More sharing options...
ammcinnis Posted April 23, 2021 Share Posted April 23, 2021 (edited) When you turn the system OFF, the airflow control dampers will remain in their current positions. If you don't want outside air, for example, you need to select RECIRC before turning the system OFF. My recommendation is to normally leave the system in FULL AUTO mode and adjust the TEMP dial up or down a degree or two at a time, until the cabin temperature stabilizes at a point where you're comfortable. Edited April 23, 2021 by ammcinnis "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
