samuel082799 Posted April 9, 2021 Share Posted April 9, 2021 I'm looking into getting a KS Tech CAI for my 2005 Outback XT. Here the link: http://www.kstech.biz/legacy-gt-megamaf-73mm-big-maf-cold-air-intake-type-2/ I'm wondering if I'm going to need to get a bigger MAF sensor since the housing is so much larger than the factory housing. I do my own tunning so I got that part covered I'm just wondering if it will max at my stock MAF sensor. Thanks Link to comment Share on other sites More sharing options...
dwmccauley01 Posted April 9, 2021 Share Posted April 9, 2021 Maxing out the MAF depends on your intake g/s not necessarily the size of the intake. Depending what other mods have been done, 73mm should be alright to scale. Sent from my SM-G970U using Tapatalk Link to comment Share on other sites More sharing options...
samuel082799 Posted April 9, 2021 Author Share Posted April 9, 2021 Maxing out the MAF depends on your intake g/s not necessarily the size of the intake. Depending what other mods have been done, 73mm should be alright to scale. Sent from my SM-G970U using TapatalkOk, the only thing I haven't done to it is a turbo and I'm no where near making out the maf right now but that's probably because I'm on the stock intake box. I imagine if a new maf was required they would state that on the website, but I just wanted to clarify Sent from my SM-G770U1 using Tapatalk Link to comment Share on other sites More sharing options...
Pleides Posted April 11, 2021 Share Posted April 11, 2021 What power level are you aiming for? Our MAF sensors are very sensitive to the slightest changes in air volume/density/dirt on the sensor and messing with the intake often causes more issues than it's worth. The factory intake moves a lot of air as well. Link to comment Share on other sites More sharing options...
samuel082799 Posted April 13, 2021 Author Share Posted April 13, 2021 What power level are you aiming for? Our MAF sensors are very sensitive to the slightest changes in air volume/density/dirt on the sensor and messing with the intake often causes more issues than it's worth. The factory intake moves a lot of air as well.I'm aiming for 450 whp, all I have left is a CAI and a big turbo. But I want to do the CAI now because I'm going to be renting a dyno soon and I want to get it dialed with this setup, because it's going to be awhile until I do the big turbo Sent from my SM-G770U1 using Tapatalk Link to comment Share on other sites More sharing options...
