legacydreamin.jp Posted March 29, 2021 Share Posted March 29, 2021 (edited) Picked up a 5MT for cheap from a 98 outback 2.5.... that 5MT has 4.11 gears in the front. I have a 96 legacy 4eat with 4.11 gears. I was wondering if i can use my rear diff with the manual or do i have to swap the diff too... Dumb question but couldnt find anything on this. (edit) update on the swap... Pulled the center diff and started to weld the diff. Edited March 31, 2021 by legacydreamin.jp Link to comment Share on other sites More sharing options...
Brighton96 Posted March 29, 2021 Share Posted March 29, 2021 If the gear ratios are the same then you should just be able to use the original rear diff Link to comment Share on other sites More sharing options...
