bjazul Posted March 26, 2021 Share Posted March 26, 2021 I have a '97 Outback that has been sitting for about 2 years and I want to see if I can get it going again. Unfortunately, this was not planned! So far I've changed the oil, battery, fuel filter, and siphoned out the old gas and put some fresh gas in. My understanding is that I need to disable the ignition system to get some oil through the engine before starting it. Could I do that by pulling the engine ignition system fuse in the passenger fuse box? Is there anything else I may need to do before giving it a try? Link to comment Share on other sites More sharing options...
Brighton96 Posted March 26, 2021 Share Posted March 26, 2021 You could just unplug the coil and also remove the fuel injector/pump fuse. Don't want to wash the cylinders with fuel by accident. Subarus don't have an oil pressure gauge so you will just have to guess how many rotations is enough, I'd say 6-12 rotations should do it. Link to comment Share on other sites More sharing options...
bjazul Posted March 26, 2021 Author Share Posted March 26, 2021 Thanks. I'll give that a try. Link to comment Share on other sites More sharing options...
doublechaz Posted March 27, 2021 Share Posted March 27, 2021 Two years is not good, but it also is not a big problem. I resurrected one parked eight years without prep. Its engine was fine after all new hoses, belts and seals. The rest of it was a mess as well, brakes, shocks wheel bearings.... You'll likely have no trouble with just what you've already posted. Link to comment Share on other sites More sharing options...
bjazul Posted March 27, 2021 Author Share Posted March 27, 2021 It started! What a relief! I think it's now time to pass it on to someone with more time and skill. Although I'm interested in getting it in better condition, I'm not set up to replace all the hoses, belts and seals. And it will be nice to have the garage space free again. Thanks for the help! Link to comment Share on other sites More sharing options...
doublechaz Posted March 27, 2021 Share Posted March 27, 2021 (edited) I must have mis-spoke. I don't think you will need to do all those things. They start to become an issue when it has sat much longer than yours did. Edited April 1, 2021 by doublechaz Link to comment Share on other sites More sharing options...
bjazul Posted March 30, 2021 Author Share Posted March 30, 2021 Thanks for the clarification. Good to know it won't necessarily need those things to get it back on the road. And it's actually my brother-in-law's car which I took on to help him out. I would be selling it anyway because he got a new car back when he parked it. Link to comment Share on other sites More sharing options...
