samuel082799 Posted January 30, 2021 Share Posted January 30, 2021 So I got a little pin hole in my stock BOV hose so I bought a samco silicon one. I'm wondering if anyone has used this hose with a grimmspeed TMIC. I'm not sure if the adapter that comes with the grimmspeed intercooler will slide over the samco hose. I may have to rig something up to work, but I'm curious to see if anyone else has done something with this combo. Thanks. Sent from my SM-G770U1 using Tapatalk Link to comment Share on other sites More sharing options...
DoctorDaveLGT Posted January 30, 2021 Share Posted January 30, 2021 I have this setup and it will work. Link to comment Share on other sites More sharing options...
Marvick08GT Posted January 30, 2021 Share Posted January 30, 2021 It doesn't work with the adapter, I have always just stretched it a bit. Link to comment Share on other sites More sharing options...
samuel082799 Posted January 30, 2021 Author Share Posted January 30, 2021 So the samco hose will be able to reach the bov without an extension? Sent from my SM-G770U1 using Tapatalk Link to comment Share on other sites More sharing options...
Marvick08GT Posted January 30, 2021 Share Posted January 30, 2021 I have done it on 3 legacy vehicles to date. Once you install it you will see you can stretch it a bit. Good luck! Link to comment Share on other sites More sharing options...
DoctorDaveLGT Posted February 1, 2021 Share Posted February 1, 2021 It doesn't work with the adapter, I have always just stretched it a bit. Just curious, what issue did you run into where the adapter didn't work for you? Link to comment Share on other sites More sharing options...
Marvick08GT Posted February 1, 2021 Share Posted February 1, 2021 Squeezing the metal piece into the new BPV hose. Without that to secure inside, the clamp will be loose on the adapter. Looks better as well IMO Link to comment Share on other sites More sharing options...
DoctorDaveLGT Posted February 1, 2021 Share Posted February 1, 2021 (edited) Huh, I didn't have any issues with that. Looks aside, the GS intercooler works with the stock bpv hose and the samco is just a silicon replacement so I guess chalk it up to YMMV. EDIT: To clarify though my setup isn't the same as it is with the OEM bpv hose. I used the metal cylinder as the connection point and each hose is clamped to it. Edited February 1, 2021 by DoctorDaveLGT Link to comment Share on other sites More sharing options...
