peerless Posted December 14, 2020 Share Posted December 14, 2020 Yes, its what I want to do, as a matter of fact I want it to show MORE mileage then it is currently. Back story is I just bought a 02 Legacy Wagon that showed 135,000 on the ode, although the car is totally worn out. Did a car fax and my suspicions where true. 07/25/2019 the mileage was 231,421 09/21/2019 the mileage went to 128,010 Went in to Joes Gas and Smog for a emissions test and came out a 100,000 miles younger, Anyways it is not fair to me or to a future owner to have a misrepresented mileage so I would like to correct it. I can easily correct it via the DMV paperwork but I also want the odo to reflect the true mileage. Not sure if someone just swapped in a different cluster or if they took the speed sensor out of the trans and turned it backwards with a drill motor? is that possible. Anyways that's my question for the day. Thanks, Link to comment Share on other sites More sharing options...
boxkita Posted December 14, 2020 Share Posted December 14, 2020 If you are going to fix it, make it worth the effort. Set it to 10 miles and sell it as low mileage original Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Brunzo Posted December 14, 2020 Share Posted December 14, 2020 Odometer reading is stored in cluster chip along with other cluster info. Find the guy who can read it for you and hopefully he can change it as well Link to comment Share on other sites More sharing options...
