Rittmeister Posted November 9, 2020 Share Posted November 9, 2020 I've been rocking Konis with H&R springs on my '09 Outback for under a week but results are very favorable. I'm wondering how folks have gone about reaching the adjusters in the rear. In my 2012 Legacy the upper strut mount was under the floor. I cut a small hole in the trunk carpet and was able to easily reach them. In my '09, the upper mounts are closer to the wheel wells, and from above they're more under the side trim than they are under the floor. Getting the adjusters in there is a real pain. Anybody got a (hopefully cheap/easy) solution? Link to comment Share on other sites More sharing options...
DoctorDaveLGT Posted November 9, 2020 Share Posted November 9, 2020 I was going to go this route but haven't gotten to making it yet. I've already drilled small holes in the rear cargo area for easy access and just use some interior panel retainer clips to cover the holes. https://grassrootsmotorsports.com/forum/grm/koni-sport-diy-extended-adjuster/62936/page1/ Link to comment Share on other sites More sharing options...
Rittmeister Posted November 9, 2020 Author Share Posted November 9, 2020 I was going to go this route but haven't gotten to making it yet. I've already drilled small holes in the rear cargo area for easy access and just use some interior panel retainer clips to cover the holes. https://grassrootsmotorsports.com/forum/grm/koni-sport-diy-extended-adjuster/62936/page1/ I ran across this in my searching. I've got so many Koni plastic adjusters around here I could easily spare one haha. Any chance you have a pic of where you cut the hole you mentioned? Link to comment Share on other sites More sharing options...
Max Capacity Posted November 9, 2020 Share Posted November 9, 2020 (edited) Having seen that link, could you just buy some heavy wall. say 1/4" tubing squeeze one end so it fits over the adjuster in the shock. You can even bend a right angle in the other end to use as a handle ? Edited July 9, 2021 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DoctorDaveLGT Posted November 10, 2020 Share Posted November 10, 2020 I ran across this in my searching. I've got so many Koni plastic adjusters around here I could easily spare one haha. Any chance you have a pic of where you cut the hole you mentioned? Yea, I can grab one later today after work and upload it. Max - I don't see why you couldn't do that. Seems like there could be plenty of variations to get to the same end result. Link to comment Share on other sites More sharing options...
Rittmeister Posted November 10, 2020 Author Share Posted November 10, 2020 Yea, I can grab one later today after work and upload it. That'd be awesome. I can measure all day but I'll still put the hole in the wrong place. Having a visual aid would be a huge help. Link to comment Share on other sites More sharing options...
DoctorDaveLGT Posted November 10, 2020 Share Posted November 10, 2020 Here you go. The adjuster sits very close to the interior trim panel and technically sits just left (~1 cm) of the carpet split between the seat back and sway bar areas. Link to comment Share on other sites More sharing options...
Rittmeister Posted November 11, 2020 Author Share Posted November 11, 2020 Sweet! Thanks for that, it's a big help. Link to comment Share on other sites More sharing options...
lilredwagon Posted November 14, 2020 Share Posted November 14, 2020 Having see that link, could you just buy some heavy wall. say 1/4" tubing squeeze one end so it fits over the adjuster in the shock. You can even bend a right angle in the other end to use as a handle ? I did exactly this. On my other car, there is a strut tower bar obscuring access to the top adjustment. So I just used a small tube, I don't know what size, but I believe it was more than 1/4". Maybe 1/2"? But I squeezed one end in a vice, and bent the other end into a right angle so I could turn it. Works great! Link to comment Share on other sites More sharing options...
Rittmeister Posted July 9, 2021 Author Share Posted July 9, 2021 Back from the dead! I (finally!) built a tool using a cut-up Koni adjuster and 8" of 1/2" conduit like the GRM thread suggested. It works perfectly, and I found that I could use the tool itself to wedge the interior trim aside (while kneeling in the back of my wagon) to get to the adjusters, so at least for now I'm not even going to drill holes in the panel. Thanks for all input. Link to comment Share on other sites More sharing options...
JJr Posted July 10, 2021 Share Posted July 10, 2021 Please post a pic where you drilled the hole for the wagon Rittmeister Link to comment Share on other sites More sharing options...
Rittmeister Posted July 10, 2021 Author Share Posted July 10, 2021 Please post a pic where you drilled the hole for the wagon Rittmeister Maybe I wasn't clear. I didn't drill a hole. I used the tool itself to push the trim aside and get onto the adjuster. See DoctorDaveLGT's pic for where he put the hole. Link to comment Share on other sites More sharing options...
JJr Posted July 10, 2021 Share Posted July 10, 2021 Sorry, Thanks Link to comment Share on other sites More sharing options...
