LegacyGIL Posted November 1, 2020 Share Posted November 1, 2020 I have a Subaru Legacy 2010 I drove around 230000. Right now I have one problem. When you turn right or turn left then I am hearing a sound “tuk tuk tuk” sound. But when I took my car in the morning there was no sound after a few minutes of drive the sound appears. Please let me know what is the cause of the problem Thanks Sent from my iPhone using Tapatalk Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
ttnio Posted November 1, 2020 Share Posted November 1, 2020 welcome. cv axle replacement on the "tuk"... for starters. Link to comment Share on other sites More sharing options...
LegacyGIL Posted November 4, 2020 Author Share Posted November 4, 2020 Mine is a manual car and one of the person told me I need to change viscous clutch. Is it related to the transmission? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Marvick08GT Posted November 4, 2020 Share Posted November 4, 2020 The center differential is the viscous clutch. It is in the tailshaft of the transmission. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 4, 2020 Share Posted November 4, 2020 Yeah. If the CV axles are in good shape, then it may well be the center differential. I had to change mine because I drove on uneven tires for an extended period of time. As far as I understand, doing so makes the center diff overheat and then partially fail. In my case, there was also a whining though during acceleration IIRC. Link to comment Share on other sites More sharing options...
Diavolo Posted November 4, 2020 Share Posted November 4, 2020 its the wheel bearing Link to comment Share on other sites More sharing options...
LegacyGIL Posted November 19, 2020 Author Share Posted November 19, 2020 Yeah. If the CV axles are in good shape, then it may well be the center differential. I had to change mine because I drove on uneven tires for an extended period of time. As far as I understand, doing so makes the center diff overheat and then partially fail. In my case, there was also a whining though during acceleration IIRC. How much did you spend to fix the center differential Mine 2010 Subaru Legacy manual 2.5i Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
LegacyGIL Posted November 19, 2020 Author Share Posted November 19, 2020 (edited) its the wheel bearing Sorry bro. I am sure it’s not wheel bearing. If the noise is due to the wheel bearing then we will hear the sound continuously.. When I drive around 10 to 15 min then there is no sound when you turn right or left But after 15 min that it produce tuck tuck sound when you turn your car right or left Sent from my iPhone using Tapatalk Edited November 19, 2020 by LegacyGIL Link to comment Share on other sites More sharing options...
boxkita Posted November 19, 2020 Share Posted November 19, 2020 Sorry bro. I am sure it’s not wheel bearing. If the wheel bearing we will hear the sound continuously.. Sent from my iPhone using Tapatalk free advice from internet. you're getting your money's worth Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted November 19, 2020 Share Posted November 19, 2020 buying the part and doing yourself? getting work done at dealer? getting work done where you got original diagnosis? each have different costs Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
LegacyGIL Posted November 19, 2020 Author Share Posted November 19, 2020 buying the part and doing yourself? getting work done at dealer? getting work done where you got original diagnosis? each have different costs I can’t do it myself. I am planning to give to a garage Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
boxkita Posted November 19, 2020 Share Posted November 19, 2020 I can’t do it myself. I am planning to give to a garage Sent from my iPhone using Tapatalk why not take it back to place that gave you the diagnosis? they should have given you an estimate? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
LegacyGIL Posted November 19, 2020 Author Share Posted November 19, 2020 why not take it back to place that gave you the diagnosis? they should have given you an estimate? They estimated around 1600$+tax Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
boxkita Posted November 19, 2020 Share Posted November 19, 2020 probably close. parts aren't cheap. labor will be 4-6 hours maybe more depending on what else is wrong. no idea where you live, but if rusty, then other issues maybe a problem. be sure to get a warranty on the work Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
LegacyGIL Posted November 19, 2020 Author Share Posted November 19, 2020 They estimated around 1600$+tax Sent from my iPhone using Tapatalk Is it worth to pay and the job done or do I need to change the car? Is there any other thing I need to take care of my car I mean any maintenance ? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
LegacyGIL Posted November 19, 2020 Author Share Posted November 19, 2020 (edited) probably close. parts aren't cheap. labor will be 4-6 hours maybe more depending on what else is wrong. no idea where you live, but if rusty, then other issues maybe a problem. be sure to get a warranty on the work I live in Montréal, Québec . Do you know any garage which will fix the problem? Sent from my iPhone using Tapatalk Edited November 19, 2020 by LegacyGIL Link to comment Share on other sites More sharing options...
boxkita Posted November 19, 2020 Share Posted November 19, 2020 Is it worth to pay and the job done or do I need to change the car? Is there any other thing I need to take care of my car I mean any maintenance ? Sent from my iPhone using Tapatalk 230,000km? what's the last service you did and how long ago? given the issue, perhaps you should get the tires checked for being improperly sized. check the cv boots. check timing belt/chain. oil change. diff/transmission fluid change. check brakes for sticking and bleed them. check bushings on suspension (probably cracked some of them). a new car is 35000 usd more or less. Used car $500-100,000. A 2010 legacy manual is a somewhat unique car. You could probably sell it for the same as the current repair costs and move into something less costly maintenance wise Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 19, 2020 Share Posted November 19, 2020 How much did you spend to fix the center differential Mine 2010 Subaru Legacy manual 2.5i Sent from my iPhone using Tapatalk I did the job myself and bought the part. I think the center diff was close to 500$. Link to comment Share on other sites More sharing options...
LegacyGIL Posted November 20, 2020 Author Share Posted November 20, 2020 230,000km? what's the last service you did and how long ago? given the issue, perhaps you should get the tires checked for being improperly sized. check the cv boots. check timing belt/chain. oil change. diff/transmission fluid change. check brakes for sticking and bleed them. check bushings on suspension (probably cracked some of them). a new car is 35000 usd more or less. Used car $500-100,000. A 2010 legacy manual is a somewhat unique car. You could probably sell it for the same as the current repair costs and move into something less costly maintenance wise I used to change the oil every 5000 km and I changed 4 brake disc and pad. I used 22550r17 for summer and 20560r16 for winter. I changed two shock in the front Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
apexi Posted November 20, 2020 Share Posted November 20, 2020 (edited) This member is from montreal and might be able to help, maybe pm him and ask him if he can recommend a shop. https://legacygt.com/forums/member.php?u=88421 I also did my center diff myself, it's not too bad. I got the part online for $450, gear oil rtv $10 or so. Exhaust gaskets and possibly new spring bolts, $20-$50? Friggin donut gasket and spring bolts and springs are expensive for what they are. Edit: Oh.. kinda forgot about gear oil too. Red line 75w-90ns is my favorite since it shifts really well in cold weather, but that'll set you back like $60 for 4 quarts. Edited November 20, 2020 by apexi Link to comment Share on other sites More sharing options...
Mr-C Posted November 20, 2020 Share Posted November 20, 2020 Hey, Not many Subaru specialist shops in the Montreal region....you can give a call to Swap Shop in Blainville they've been around awhile now and are good guys. I might also have a buddy that can help if you're willing to go to the South Shore....of course you can always go to a Dealer Link to comment Share on other sites More sharing options...
LegacyGIL Posted December 6, 2020 Author Share Posted December 6, 2020 Hey, Not many Subaru specialist shops in the Montreal region....you can give a call to Swap Shop in Blainville they've been around awhile now and are good guys. I might also have a buddy that can help if you're willing to go to the South Shore....of course you can always go to a Dealer Sure I could go to south shore. Please let me know when he is free? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
LegacyGIL Posted December 6, 2020 Author Share Posted December 6, 2020 This member is from montreal and might be able to help, maybe pm him and ask him if he can recommend a shop. https://legacygt.com/forums/member.php?u=88421 I also did my center diff myself, it's not too bad. I got the part online for $450, gear oil rtv $10 or so. Exhaust gaskets and possibly new spring bolts, $20-$50? Friggin donut gasket and spring bolts and springs are expensive for what they are. Edit: Oh.. kinda forgot about gear oil too. Red line 75w-90ns is my favorite since it shifts really well in cold weather, but that'll set you back like $60 for 4 quarts. I texted the person but I didn’t get any response. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
boxkita Posted December 6, 2020 Share Posted December 6, 2020 Sure I could go to south shore. Please let me know when he is free? Sent from my iPhone using Tapatalk I texted the person but I didn’t get any response. Sent from my iPhone using Tapatalk you could call the shop and ask for an appointment? you could call the person instead of texting? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
apexi Posted December 6, 2020 Share Posted December 6, 2020 you could call the shop and ask for an appointment? you could call the person instead of texting? Eeeeassssyy yooooo, I think he's asking about the friend of Mr-C who could help, and that he sent a PM to the member I suggested talking to. Hey, I might also have a buddy that can help if you're willing to go to the South Shore.... This member is from montreal and might be able to help, maybe pm him and ask him if he can recommend a shop. https://legacygt.com/forums/member.php?u=88421 Link to comment Share on other sites More sharing options...
