AVGxp Posted October 19, 2020 Share Posted October 19, 2020 So I removed the TGV motor to make it easier to remove the oil line and I moved the position of the tgv by mistake, I tried to set it to where it was as best as I could before reinstalling. I just wanted to know if there is a procedure I should follow to reinstall the motor. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 19, 2020 Share Posted October 19, 2020 covertrussian's thread may have some info. It has been talked about. Have you asked Google how to ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Fabsx Posted October 20, 2020 Share Posted October 20, 2020 I believe you go 90 degrees with the sensor and then pop it in. Meaning you preload the sensor 90 degrees off and then when it’s in the right location, it’s on correctly. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
AVGxp Posted October 20, 2020 Author Share Posted October 20, 2020 covertrussian's thread may have some info. It has been talked about. Have you asked Google how to ? I did, I can use the name you provided to search now but all I found was threads about how I should just delete the tgvs, I don't want to take that on with the amount of changes I'm making now. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 20, 2020 Share Posted October 20, 2020 (edited) https://legacygt.com/forums/showthread.php/covertrussians-05-lgt-build-thread-218363.html?t=218363&highlight=covertrussian It could be in there. I put his name in the box from the "search" button on the blue bar up top I do know you have to do something about preloading it, by the 90 degree rotation, clockwise ? Edited October 20, 2020 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
