CherrySubee Posted September 17, 2020 Share Posted September 17, 2020 Hi Guys, newbie here. First post. I have had a problem getting the cars starter to start the car when I drive and shut it off. This is only when its about 85 or higher. Been all over YOUTUBE for it. New starter 1 year old. Runs 112,000 miles great. Garage kept, original owner. No engine codes showing. When I use a remote starter on it it starts right up. I would love to talk to someone who has had this problem and has had it corrected. It's not the starter or solenoid. Thanks gents. Link to comment Share on other sites More sharing options...
Brighton96 Posted September 17, 2020 Share Posted September 17, 2020 Does the starter engage or no? Because a sign that the coil is failing is that is won't work consistently when it's hot. Link to comment Share on other sites More sharing options...
doublechaz Posted September 17, 2020 Share Posted September 17, 2020 I had a hot only starting problem a while back that was not the starter. The positive battery cable was corroded back inside the wire about an inch from the connector. This same idea would also apply to the negative battery cable and the various grounds from the engine and trans to the body/frame. Also, I did have a parts store starter that only lasted about 1 year. Not all parts stores sell the same quality parts. Link to comment Share on other sites More sharing options...
CherrySubee Posted September 21, 2020 Author Share Posted September 21, 2020 Thanks Guys, The starter works fine when I connect a remote starter button/switch to the solenoid and to the positive battery terminal. Anyone have this? I saw the tip on YouTube. Link to comment Share on other sites More sharing options...
ehsnils Posted September 21, 2020 Share Posted September 21, 2020 Then it's time to check neutral switch. If it's a manual then there shall be a switch on the clutch. On an automatic there might also be a switch on the brake pedal. Both in addition to neutral switch. On the manual gearbox vehicles there's also a starter interlock relay located under the dashboard. The ignition lock can also be faulty. Look here: http://jdmfsm.info/Auto/Japan/Subaru/Legacy_Outback/1997/Service%20Manual/WIRING%20DIAGRAM%20SECTION/WIRING%20DIAGRAM/ So just continue to dig. Link to comment Share on other sites More sharing options...
