Tehnation Posted August 25, 2020 Share Posted August 25, 2020 Is the driver door the same for all 4th gens. Same with the bumper? Link to comment Share on other sites More sharing options...
jaylew Posted August 25, 2020 Share Posted August 25, 2020 from what I know, the metal shell...yes. I know for sure the handle mechanism is different so keep that in mind if you are swapping over components and mix matching between MY's Wagon is LIFE! - 267,000 miles and climbing Unofficial Build (Restoration) Thread Steering Rack Rebuild Link to comment Share on other sites More sharing options...
Tehnation Posted August 25, 2020 Author Share Posted August 25, 2020 I just need the outer part for the door. Looks like the newer 4th gen bumpers with the lights require you to change the brackets and tail lights as well. The older ones have taller lights, so the bumper is a little bit shorter under the lights versus the newer one. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 25, 2020 Share Posted August 25, 2020 All doors are the same. search http://www.car-parts.com 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
