Tehnation Posted August 24, 2020 Share Posted August 24, 2020 So I got a map on the car that can let it move, but while driving around I noticed the clutch would not come back up smoothly, it sticks a little. Anyone experience this before or know what may cause this? Link to comment Share on other sites More sharing options...
Marvick08GT Posted August 24, 2020 Share Posted August 24, 2020 Could be arm or pivot related. Have you bled the clutch master and slave? Link to comment Share on other sites More sharing options...
Tehnation Posted August 24, 2020 Author Share Posted August 24, 2020 I bled it at the clutch slave I believe. Do you need to bleed it in 2 places? I just bled it by the valve right on top of the tranny between the engine/tranny. It shifts and drives, its just that when I push it to the floor it doesn't spring back up all the time, but it will come up on its own, just feels weird. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 24, 2020 Share Posted August 24, 2020 fork about to break? or TOB about to fail or failing? Do you have the TSK3 kit installed? Link to comment Share on other sites More sharing options...
Tehnation Posted August 24, 2020 Author Share Posted August 24, 2020 nope no tsk3 kit. Fork and snout were in good shape when I installed it. New tob as well. Link to comment Share on other sites More sharing options...
Tehnation Posted August 25, 2020 Author Share Posted August 25, 2020 damnit.... whats the easiest way to install the tsk3 kit? Moving the tranny back? I do not want to pull the engine again... I had it before the engine rebuild, pulled it after when I realized I didn't have a new oversized tob when I was reinstalling, I actually pulled the motor again and had time to do it, but it completely slipped my mind.... so I just used what came with the clutch. Guess I need to go find out who has my tranny jack....or would it be faster to just pull the engine away just a little, would have to dump coolant...again. Link to comment Share on other sites More sharing options...
Infosecdad Posted August 25, 2020 Share Posted August 25, 2020 I would rebleed before looking at pulling something Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 25, 2020 Share Posted August 25, 2020 Yeah, rebleed again. You know that TSK3 kit, it's nice but I don't think the bearing is that high quality actually. I had an issue with my kit, which could have been user error. Essentially, the sleeve came loose on mine and was moving around with the TOB. That was the cause of my weird engagement point which happened all of the sudden. Anyway, yeah, rebleed and check. If no fix, then not too sure. Link to comment Share on other sites More sharing options...
rhino6303 Posted August 25, 2020 Share Posted August 25, 2020 Yeah, rebleed again. You know that TSK3 kit, it's nice but I don't think the bearing is that high quality actually. I had an issue with my kit, which could have been user error. Essentially, the sleeve came loose on mine and was moving around with the TOB. That was the cause of my weird engagement point which happened all of the sudden. Anyway, yeah, rebleed and check. If no fix, then not too sure.In my research I've found references that a throwout bearing from an 86-99 Celica is the same size as the tsk3 bearing. You can get an SKF bearing that should be pretty good quality. SKF N4087 is a part number that should work. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 25, 2020 Share Posted August 25, 2020 if you order a TSK3 kit, make sure you can return it. My wagon doesn't have one. I do have a tranny jack if you need to borrow it. I think your problem has been discussed here before, have you asked "google " 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 25, 2020 Share Posted August 25, 2020 In my research I've found references that a throwout bearing from an 86-99 Celica is the same size as the tsk3 bearing. You can get an SKF bearing that should be pretty good quality. SKF N4087 is a part number that should work. Rhino, you always find good alternative options for our platform. Thanks for sharing. Link to comment Share on other sites More sharing options...
rhino6303 Posted August 25, 2020 Share Posted August 25, 2020 Rhino, you always find good alternative options for our platform. Thanks for sharing.Haha. Thanks! I just like to research I guess. I also just found the correct pins for doing the steering wheel controls. My current setup isn't working correctly all the time and I suspect it's because the lins aren't correct when you swap them to the green connector. I like things to function like oem. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 25, 2020 Share Posted August 25, 2020 Nice. I have my steering wheel controls hooked up to a little interface (joycon exr) which goes with my Nexus 7. Never used to have steering wheel controls before though. Been working great for the past 3-4 years now. Wow time flies! Back to clutches and TOB though Link to comment Share on other sites More sharing options...
