fullmonte77 Posted July 31, 2020 Share Posted July 31, 2020 I have a 2015 and would like to add fog lights. I know my 07 I use to have already had the wiring for the factory lights hidden in the bumper. Is the 15 the same way? I know I will need a switch but will I need anything else? My 07 did require a relay also. Any help would be greatly appreciated. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
halvarez430 Posted August 13, 2020 Share Posted August 13, 2020 Yeah same way the wiring harness is hidden Sent from my SM-G975U using Tapatalk Link to comment Share on other sites More sharing options...
SubiFTW Posted August 14, 2020 Share Posted August 14, 2020 I have a 2015 and would like to add fog lights. I know my 07 I use to have already had the wiring for the factory lights hidden in the bumper. Is the 15 the same way? I know I will need a switch but will I need anything else? My 07 did require a relay also. Any help would be greatly appreciated. Sent from my iPhone using Tapatalk I have stock fog assembly with bulbs if you’re interested. You would just need to get the switch and anything else Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
aki334 Posted August 25, 2020 Share Posted August 25, 2020 I have a 2015 and would like to add fog lights. I know my 07 I use to have already had the wiring for the factory lights hidden in the bumper. Is the 15 the same way? I know I will need a switch but will I need anything else? My 07 did require a relay also. Any help would be greatly appreciated. Sent from my iPhone using Tapatalk Yes, fog light connectors are there waiting for you wrapped with blue electrical tape. Also there is a connector waiting for you under the dash on the left side under the steering wheel for your switch. You will have to buy OEM switch, blue relay that plugs in the fuse box under the hood and fog lights. I got the kit from dealer. Go to Subaru dealer parts online search for fog lights and you will find pdf file with installation instructions that comes with the kit so you can get the idea. I recommend that you get the OEM switch and do it right because even instrument cluster will show fog lights on with OEM setup. Link to comment Share on other sites More sharing options...
fullmonte77 Posted August 26, 2020 Author Share Posted August 26, 2020 Yes, fog light connectors are there waiting for you wrapped with blue electrical tape. Also there is a connector waiting for you under the dash on the left side under the steering wheel for your switch. You will have to buy OEM switch, blue relay that plugs in the fuse box under the hood and fog lights. I got the kit from dealer. Go to Subaru dealer parts online search for fog lights and you will find pdf file with installation instructions that comes with the kit so you can get the idea. I recommend that you get the OEM switch and do it right because even instrument cluster will show fog lights on with OEM setup. I ended up ordering an aftermarket light set and an oem switch and relay. They should be here end of the week. The aftermarket lights have the same connectors as the oem and mount the same. Cost me $100 total. I didn’t want to spend over$200 for the oem lights. I found the wiring for the lights and the switch. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
d0bdish18 Posted August 29, 2020 Share Posted August 29, 2020 Can you please share with aftermarket set you got? I'm planning do basically the same thing. Sent from my Pixel 4 using Tapatalk Link to comment Share on other sites More sharing options...
