Peppe Posted June 11, 2020 Share Posted June 11, 2020 Does 2020 Legacy have actual tire readings in Canada? Owners manual shows how to do it but says US models? Not in settings anywhere. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 17, 2020 Share Posted June 17, 2020 Just to point out. You should be checking tire pressure with a good quality tire pressure gauge you bought from an auto parts store. IMO the car is just a reference, as tire pressures will vary as your driving. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
plm42 Posted June 18, 2020 Share Posted June 18, 2020 Does 2020 Legacy have actual tire readings in Canada? Owners manual shows how to do it but says US models? Not in settings anywhere.Nope. My previous (2015) did not have TPMS sensors, nor does the **CANADIAN** 2020. A good thing if you ask me. One less thing to worry about when buying tires. You can use any simple pressure gauge bought at your local Canadian tire. Sent from my SM-G960W using Tapatalk Link to comment Share on other sites More sharing options...
