LMBelo Posted May 13, 2020 Share Posted May 13, 2020 Hi, guys! Got excessive time lag when select lever is moved from N to D or from N to R. Service manual tells that it may be Control Module. But the Transmission Control Module isn't present where service manuals tells it whould has to be. So, it looks like the Engine Control Unit is also responsable for transmission, is it correct? So, does anyone have service manual for this model? Link to comment Share on other sites More sharing options...
Brighton96 Posted May 13, 2020 Share Posted May 13, 2020 I'm pretty sure the ECU controls the trans. Also is there a lag when it shifts while driving it? Cause if so, you can try doing a few fluid exchanges but chances are it's just a tired trans. Link to comment Share on other sites More sharing options...
LMBelo Posted May 13, 2020 Author Share Posted May 13, 2020 Do not presents time lag when it shifts, but some times it shifts weird, like if it's reducing a gear... also flushed fluid two times, but did not work. Link to comment Share on other sites More sharing options...
Senseless1 Posted May 14, 2020 Share Posted May 14, 2020 https://sl-i.net/FORUM/showthread.php?18087-Subaru-Factory-Service-Manuals-(FSM)-Every-Model-USDM-EU For factory service manuals. Good forum, but too many rules for me. Link to comment Share on other sites More sharing options...
LMBelo Posted May 14, 2020 Author Share Posted May 14, 2020 That's the same service manual as mine, and also refers to a tcm. Link to comment Share on other sites More sharing options...
choover1101 Posted May 16, 2020 Share Posted May 16, 2020 My 96 and my 99 TCU were both located on top of the trans tunnel under the radio/HVAC . Sent from my SM-N950U1 using Tapatalk Link to comment Share on other sites More sharing options...
