MPacMan15 Posted May 7, 2020 Share Posted May 7, 2020 I have a 2009 Legacy 3.0R with 103k miles on the clock, have owned it since 45k miles and its been a great car. Recently I have been having some weird check engine light issues that scan to bank 2 misfires on all three cylinders, the car still runs completely normal and does not feel down on power at all. After disconnecting the battery it did have some issues with idle mainly when coming to a stop at a red light the RPM's would dip down to around 400 and it would feel like it was going to stall but never would. Also if I reved the car the RPM's would climb normally but fall really fast and again dip to around 400 and after a second bounce back up to a normal idle. After driving for around 75 miles it has since seemed to relearn and is no longer an issue. Just put brand new OEM plugs in the car as well. For the past few months pretty much at complete random I would have times where the CEL would flash for around 3-5 secs while driving then shut off and return to normal. It has now been staying on not flashing, car still runs just fine. The codes I am getting are: P0306 cylinder 6 misfire P0304 cylinder 4 misfire P0302 cylinder 2 misfire 20B12 preparatory code 20B02 preparatory code We also read the MAF and MAP sensors and they seemed to be reading steady and responding correctly. Looking at the values for the A/F Learning and Correction for banks 1&2 we thought these values might be a good bit high. Because of this and the idle relearning issues I think I have an idea of what the issue is but wanted to get some opinions before throwing parts at it. Thanks! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted May 7, 2020 Share Posted May 7, 2020 Have you checked for loose connections at the coil's ? I assume you have coil on plug ? have you cleaned the MAF sensor lately ? Use a can of MAF cleaner, give it a short spray. let it dry. Check the free stuff first before you have to take it and pay the man. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MPacMan15 Posted May 7, 2020 Author Share Posted May 7, 2020 I did clean the maf a few months back after removing the oiled k&n filter, when it first started doing this I removed all the connections on the top side of the engine and applied die electric grease to all of them. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
MPacMan15 Posted May 8, 2020 Author Share Posted May 8, 2020 Does anyone think this could be a leak at the intake manifold gaskets? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Infosecdad Posted May 8, 2020 Share Posted May 8, 2020 Does anyone think this could be a leak at the intake manifold gaskets? Sent from my iPhone using Tapatalk It's possible, if you are seeing codes for everything on a single head; look for shared functionality on that head. Link to comment Share on other sites More sharing options...
mattdrifts Posted October 27, 2020 Share Posted October 27, 2020 gona follow this have just had same issue my cel would flash rarely for a few seconds and since yesterday stayed on i ran a scan and got missfire on #1 , #3 and #5 . car seems to run fine Link to comment Share on other sites More sharing options...
