GEE-OTTO Posted May 6, 2020 Share Posted May 6, 2020 Last weekend i got a P0458 CEL and given the car has 195K miles on it, I went and bought a new Evap Purge Solenoid ($34 from local Subaru Dealer). Its pretty easy to replace as it is right on top up front of the IM. Well the real problem is a rodent chewed the wires, ALL the wires in that area (Boost Control and Evap Purge) so I need to cut out the chewed sections and replace. Now to preface this, I haven't driven my car in the 3 weeks leading up to figuring this out, so ill prob use this to replace the brittle rubber hoses which are going to crack when i try to remove the affect solenoids. My question is, what is the best splice method for the new wires? leaning toward twist and sweat sleeve but I am also able to solder. Thanks Link to comment Share on other sites More sharing options...
Chocoholic005 Posted May 6, 2020 Share Posted May 6, 2020 Solder and heat shrink is the best solution. Iwire offers replacement plugs w/ pigtails and butt connectors to make the job easy if you'd rather replace. Link to comment Share on other sites More sharing options...
