Artizan Posted May 6, 2020 Share Posted May 6, 2020 I really want to lower my car, but to be honest, the rear height really doesn't bother me much, it's the front that drives me crazy. So I got this idea, why not get lowering springs for the front only? Not sure if I should just put them on and switch the shocks when the stock ones inevitably get wrecked, or just do the combo right away. Either way, is there any reason not to lower front only? I'm only looking to drop it by like an inch. Link to comment Share on other sites More sharing options...
Eugene Onegin Posted May 6, 2020 Share Posted May 6, 2020 Why do you want to do this ? Link to comment Share on other sites More sharing options...
Artizan Posted May 6, 2020 Author Share Posted May 6, 2020 Why do you want to do this ? Looks. Gap in the front drives me crazy. Link to comment Share on other sites More sharing options...
Senseless1 Posted May 6, 2020 Share Posted May 6, 2020 It will change the dynamic stability you're used to slightly, and depending on where you live might be against the safety inspection laws. I would look at getting the front alignment adjusted as well. It's just a lot of effort for a small change. You might want to compare the investment of time and money against other mods you might be interested in. You might be surprised to learn you could save a little more and potentially upgrade all the way around or do an exhaust system instead. There are so many better ways to spend money on a car besides only changing half the suspension. Link to comment Share on other sites More sharing options...
Artizan Posted May 6, 2020 Author Share Posted May 6, 2020 It will change the dynamic stability you're used to slightly, and depending on where you live might be against the safety inspection laws. I would look at getting the front alignment adjusted as well. It's just a lot of effort for a small change. You might want to compare the investment of time and money against other mods you might be interested in. You might be surprised to learn you could save a little more and potentially upgrade all the way around or do an exhaust system instead. There are so many better ways to spend money on a car besides only changing half the suspension. I'm aware of other mods. I'm just one of the stupid ones who prioritize looks first Link to comment Share on other sites More sharing options...
DougKelly20 Posted May 10, 2020 Share Posted May 10, 2020 It's not the ride height but the spring rate I would be concerned with... most lowering springs have a different rate than stock and your car will be all out of sorts if the back end is wobbling around but the front isn't. I lowered my car with white line springs and while I like them the one thing I noticed was I got a larger front drop than the rear. Now low profile cars disappear faster under my deck in the rear view and I had to adjust my headlights. No big deal because I have the same rates all around and it handles very well, just minor inconvenience/annoyance. Link to comment Share on other sites More sharing options...
utc_pyro Posted May 10, 2020 Share Posted May 10, 2020 Most lowering springs have a rate only 10% higher than stock. That's not enough to cause major issues. Link to comment Share on other sites More sharing options...
